Old 01-02-2004, 01:57 PM   #1
pbmcauliffe
pbmcauliffe's Avatar
Leaf spring question
My brother in-law has a 70 (3/4 ton) 4x4 with factory negative arch front springs that are worn out and sagging more. Would a set of negative arch front springs from a newer (1980's) 3/4 ton 4x4 work. Same spring rate, pin offset, etc.
TIA
pbmcauliffe is offline   Reply With Quote
Old 01-02-2004, 02:43 PM   #2
playtoy1
no those springs wont work the fronts are different lengths by a couple of inchs use your main leaf than the others would work
playtoy1 is offline   Reply With Quote
Old 01-02-2004, 10:59 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
yep 73 and newer front springs are 3" longer. you could get a set of long add-a-leafs and get about 1.5". Don't get the short ones they are too stiff and will cause the spring pack to bend funky.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
