04-13-2014, 12:04 PM | #1 |
Rottenwood Garage Member
1966 stock wiper blade search. No luck finding quality.
I have read a post or 10 about the same issue. I am having a bear of a time finding quality blades that will actually not come off the stock or aftermarket 66 arms. They all seem to have enough slop to twist right off. I do not have any stock blade housings that are in good enough shape to just replace the element and I have tried several from different suppliers and local parts houses with no real success. Every set I get has too much slop. FYI, for those not familiar with the year swaps they are different (smaller) from 67-72. Below is a picture of the last set I got, originally from The Truck Shop and were sold through Tim Tygarts. They were so sloppy they would just fall off. I was told by them that their R&D team saw nothing wrong with them.!?! Also pictured is an old aftermarket blade and arm I do have that will work but I need a match for it.
Have any of you 60-66 guys had any luck finding a replacement?
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! Last edited by 72freak; 04-13-2014 at 12:48 PM. |
04-13-2014, 12:48 PM | #2 |
Re: 1966 stock wiper blade search. No luck finding quality.
Same issue I've had. The splined knobs are starting to break as well. I think it's time to find some junkyard wiper parts and try replacing the splined knobs somehow to use new arms
04-13-2014, 09:26 PM | #3 | |
HTH, Sam |
04-13-2014, 09:37 PM | #4 |
The only place I've been able to find them is carquest. And the only size they have that fit are 11". They are 11-52 ro 11-51, I can't remember which one. All the others have a bigger slot. This one I had to force on to fit.
04-13-2014, 10:14 PM | #5 |
I just installed these wiper blades and they haven't twisted off yet. The plastic piece to the left in the picture actually tightened up the wiper fitment not allowing it to twist.
http://www.ebay.com/itm/121188538529...84.m1497.l2649 |
04-14-2014, 09:21 AM | #6 |
I just purchased some "trico classic 13-122" classic wiper blades with arms, they look great nice stainless steel , only problem they did not fit, the tang on the arm is too long, it will not allow the little button to engage and hold the arm in place. Dang it, then the other blade on the drivers side fell off while being used.....Just running a little stub on the drivers side while I try and modify the arm to let the new trico fit. (I have a spare base arm and will modify it first.....Kieth
04-14-2014, 11:29 AM | #7 |
Are you looking for the red dot Trico heads or the non dot heads?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-14-2014, 11:36 AM | #8 |
i used an anco universal blade and trimmed it to length, works fine
04-14-2014, 12:13 PM | #9 | |
04-14-2014, 01:31 PM | #10 | |
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
04-14-2014, 01:37 PM | #11 |
I don't know the difference in dots v/s non dot. I am looking for the factory style wiper blades. They slide in and have a little tang and hole and they snap in and line up with the hole.
04-15-2014, 09:53 AM | #12 | |
04-15-2014, 10:15 AM | #13 |
The original wipers from the factory were the 13" trico red dots. They used blade refills instead of the whole wiper head swap. Most of the heads were replaced to the more modern style (replaced head) than the refill style. The refill style had red dots on the tops of the heads. Press the red dots and the blade assembly released from the head.
Also...most of the original Trico arms I've seen on these trucks had an adjustable head as yours and mine do. Seems that when arms were replaced they went to a one piece non-adjustable style head. I prefer the adjustable style as you can adjust the angle the wiper lays on the windshield.
04-20-2014, 08:12 AM | #14 | |
Thanks for the tip.
