Old 04-13-2014, 03:16 PM   #1
K10mashup350
Exclamation Busted seat belt bolts!
So I'm now working on the interior of my truck an the previous owner removed everything including seat belts but as they did it they busted 2 of the bolts in the floor (drivers side belt, and pass side buckle).... I'm wondering if there is anything I can do to get them out without having to get the drill n tap/die set out??... I've already tried putting visegrips on the bottom an tried to spin them out that way with no luck... Is there another spot that I could mount the belts without having issues?
Any suggestions would be helpful, thanks
K10mashup350 is offline   Reply With Quote
Old 04-13-2014, 04:18 PM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Busted seat belt bolts!
Could try a good extractor on them after soaking. But chances are you have screwed them up on the bottom side with the vice grip stunt.
Get the drill out and just get it done.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-13-2014, 04:50 PM   #3
kalbert
If they wouldn't come out without breaking off they won't come out. Mine all broke off too. You can try to drill them put but they are hard, go slow, use oil, have lots of bits ready. I cut my losses and ground the nuts off and welded new ones on.
kalbert is offline   Reply With Quote
Old 04-13-2014, 05:46 PM   #4
K10mashup350
How hard are the nuts to cut off? My cab is mounted on the frame...
Old 04-13-2014, 08:10 PM   #5
79Betty
79Betty's Avatar
Try welding a bolt onto the busted part. I've done this at work a lot on broken exhaust bolts in heads. Since u tried to vice grip the bottom those threads are screwed weld that side. Grind the top in the ca flush. The heat will weaken the bolt.
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
Last edited by 79Betty; 04-13-2014 at 08:11 PM. Reason: I suck at spelling, for reals.
79Betty is offline   Reply With Quote
Old 04-13-2014, 08:17 PM   #6
BADAZ chevy guy
BADAZ chevy guy's Avatar
I would try some heat from a torch. (Be careful not to catch anything on fire)
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 04-13-2014, 10:27 PM   #7
kalbert
Grinding them off wasn't easy either, but I was able to get them with an angle grinder and a cutoff wheel.
Old 04-14-2014, 04:58 AM   #8
K10mashup350
Well thanks for the tips guys I was able to get the old ones off... I Donno why I didn't think of it when I was trying to figure out what I was gonna do but I cut them off an put new ones in.....
Again thanks a bunch guys!!
