Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 04-13-2014, 06:15 PM   #1
Pro Performance
Pro Performance's Avatar
April Special: 14" Front & Rear Brake kit - $1,695
C10 14" Front & Rear Big Brake System - $1,695
Now that we have officially finished our front and rear 14" brake kits, made by Baer, it is time to run a special. We keep the pricing really low to begin with on these kits, but we are offering some savings this month on the front and rear kits together. Below is a few key points about our 14" brake system. We have finally gotten to a point, where we have these kits on the shelf and ready to ship.
Some pictures below show the kit installed on a stock spindle (not included). No need to change spindles, and will work with almost all aftermarket drop spindles. (McGaughys, ECE, BellTech, Western Chassis, CPP - non-modular). Complete instructions included for both front and rear.
Features & Benefits
• Available in 5-lug or 6-lug
• Front Corvette C5 Caliper (Brand New w/ Pads)
• Rear Mustang caliper with integrated parking brake (Brand New w/ Pads)
• NO machining required to install rear kit
• Machined aluminum hubs w/ Timken or SKF bearings (Pre-installed)
• Works with any stock spindle or stock style drop spindle. Requires mods to mount caliper.
• 14" cross drilled, slotted, zinc plated and directional vented rotor all around
• Lifetime warranty against rotor warping (does not include normal wear and tear)
Additional Add-Ons:
Front and Rear DOT SS Hoses: $195
Disc Brake Master Cylinder: $100
E-Brake Cables: $125
Pro Performance is offline
Old 04-14-2014, 10:32 AM   #2
Number98
Prestige Worldwide
Number98's Avatar
Re: April Special: 14" Front & Rear Brake kit - $1,695
Hey Travis, do you have any fitment templates and also what is the minimum diameter wheel required, I assume 18"?
Number98 is offline
Old 04-14-2014, 01:42 PM   #3
Pro Performance
I should have that shortly for you. It will clear in most 18's, but once I have that template, it will best to double check.... it will be tight, depending on the drop center of the wheel. The image above is shown with a 20" wheel.
Old 04-14-2014, 03:58 PM   #4
SeTx67
SeTx67's Avatar
Will this widen the track at all?
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline
Old 04-14-2014, 09:10 PM   #5
Pro Performance
No, this will not widen track width.
Old 04-17-2014, 02:26 AM   #6
Pro Performance
Just wanted to post up a link to the brake template, if any are wanting to measure to fit 18" wheels.
http://www.azproperformance.com/manuals/C078P.pdf
Old 04-21-2014, 03:26 PM   #7
Pro Performance
Ttt
Old 04-29-2014, 01:39 AM   #8
Pro Performance
We started this April special a little late, and have decided to extend a few weeks into May.
Closed Thread
