Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-13-2014, 09:28 PM   #101
Blue Rat
Re: Another 489bbc question
You could take a 454 an bore .060 an get a 468 add 4.25 crank an you have a 496.
Blue Rat is offline   Reply With Quote
Old 04-13-2014, 09:42 PM   #102
Roll'nSlo
Roll'nSlo's Avatar
Ok. That's what I thought. I just don't want to bore it .060 just incase something happens and I need to bore it again.
Roll'nSlo is offline   Reply With Quote
Old 04-14-2014, 12:33 AM   #103
68c10owner
68c10owner's Avatar
If you have your block sonic checked and its thick enough some 454 blocks can got .125 over.
Anthony
68c10owner is offline   Reply With Quote
Old 04-14-2014, 06:43 AM   #104
Blue Rat
Yep.
Old 04-14-2014, 07:17 AM   #105
Roll'nSlo
Roll'nSlo's Avatar
May do that to squeeze a little more out of it if possible.
Old 04-14-2014, 07:42 AM   #106
Blue Rat
The 468 will be more than enough if you decide to go that route.
Old 04-14-2014, 08:29 AM   #107
bbcmudtruck
If you have a standard bore block that will clean up at .30, go that route. No need in boring the block more than needed. Your not going to miss the difference between the 489 and a 496. If your starting from scratch, get ahold of cnc motor sports for a rotating assembly. They are truly balanced in house before shipped to you. Unlike jets or summit. Ideally, you'd want a 4.25 stroke crank, 6.385 rods and pistons to match accordingly. I prefer scat assemblys, but anything can be broken if abused! You'll need your rotating assembly before you take your block to the machine shop. Almost forgot, if it hasn't been mentioned yet, be sure to get an internal balanced crank. You'll need a neutral flex plate and 427 harmonic dampner.
bbcmudtruck is offline   Reply With Quote
Old 04-16-2014, 10:33 AM   #108
Kyle@FTP
If your going to put it on the bottle, Make sure you plan for that. If its just a 100 shot you will be fine with most parts but anymore and you will want a solid piston/rings and the cam will be a little different as well.
I never got the internal/external balancing. Ya sure its great to have the assembly balanced with less weight on the ends of the crank. But for a 500hm application? does it really matter that much? If he goes external he can reuse his balancer and flex plat that he has, saving a couple hundred bucks.
Kyle@FTP is offline   Reply With Quote
Old 04-16-2014, 01:13 PM   #109
bbcmudtruck
Internally balanced is much better than having weights slinging around on the outside of your motor! No matter the hp rating or even intended use, it's better. Now will the motor be fine externally balanced? Absolutely if done correctly! It will also save him a little bit of money, IF he already has a good balancer and flex plate. Just my opinion that if he's starting from scratch to do the little things to help the engine be more efficient and live longer as he goes. Again, just my opinion.
Old 04-16-2014, 04:22 PM   #110
Roll'nSlo
Roll'nSlo's Avatar
I have a complete engine plus accessories. But I'm not going to use the accessories. I'm going to internally balance it. I'm replacing all of the rotating assembly.
Old 04-18-2014, 08:06 PM   #111
Roll'nSlo
Roll'nSlo's Avatar
If your going to put it on the bottle, Make sure you plan for that. If its just a 100 shot you will be fine with most parts but anymore and you will want a solid piston/rings and the cam will be a little different as well.]
If I do add the bottle, it'll only be 100 shot.
Old 04-19-2014, 11:48 AM   #112
Kyle@FTP
Just buy quality parts and retard the timing 4* and you are good to go.
