Old 04-15-2014, 09:39 PM   #1
67-4x4
69 chevy 4x4 rolling frame
have a nice 69 4x4 frame with bellhousing 4sp trans transfer case driveshafts and clutch linkage got off board member on here but going a different route now email for pics 800.00obo
67-4x4 is offline   Reply With Quote
Old 04-15-2014, 10:06 PM   #2
Re: 69 chevy 4x4 rolling frame
K/10 or K/20? With axles? Very interested. Where about is Moon TWP? (no smart remarks,guys...heh heh) It has the Rockwell 221,right?
Old 04-15-2014, 10:32 PM   #3
jimer1964
jimer1964's Avatar
tim moon twp is out by Pittsburgh
jimer1964 is offline   Reply With Quote
Old 04-16-2014, 07:42 AM   #4
Thanks Jim
Old 04-16-2014, 09:05 AM   #5
67-4x4
special k I will get you some pics and info
Old 04-17-2014, 08:23 AM   #6
Thanks. I'd like to see which t-case and get a feel for how much rust. Usually at the various mounts and cross member unions,as well as general rail condition.
Old 04-17-2014, 09:00 AM   #7
bigrigpardo
special k if this is the frame I am thinking of he got this from me last month and it is in fantastic condition it has a sm465 and a np205 with an eaton ho52 and a dana 44 drum front. there is no rust at all between brackets. I picked a very clean very straight frame for him. just a quick blast and paint and it should look like new. its probably one of the cleanest 4wd frames I have picked in a while
bigrigpardo is offline   Reply With Quote
Old 04-17-2014, 02:10 PM   #8
Dale_Brown
Short or long bed frame?
Dale_Brown is offline   Reply With Quote
Old 04-17-2014, 05:03 PM   #9
67-4x4
it is a k20 long bed frame
Old 04-17-2014, 09:09 PM   #10
Have you e-mailed the pictures,yet? I only check e-mail every morning. Thanks BRP
Old 04-17-2014, 09:29 PM   #11
67-4x4
yes sir sent you a bunch this morning
Old 04-17-2014, 11:05 PM   #12
Ok,thanks. I'll go take look.
Old 04-18-2014, 07:05 AM   #13
Dale_Brown
Looking for the bell housing 4sp trans, transfer case, drive shafts, cross member, and clutch linkage.
Don't really need the frame, rears or steering, springs etc.....
Special-K what parts were you looking for?
Old 04-18-2014, 08:05 AM   #14
67-4x4
its all there maybe get with special k and see what he needs but id like to sell it as one thanks
Old 04-18-2014, 09:34 AM   #15
I am interested in what is being offered. I have a cab,doors,fenders,core support/grille,hood,and once I change my '72 bed,that too,along with other cast-off parts once I restore the '72. I also have a '71 350. I have the title from a truck that was stolen years ago,too. I'd have to get a reconstructed title,but see where I'm going? The frame wouldn't be much use without all the crossmembers anyway.
I have some questions. Do you have the axles shaft that's not installed in the picture? Do you know why it was pulled? Same reason the differential cover was removed,I guess. I'm thinking there must be some issue with the rear? How long has that been open? Frame looks pretty decent. When are the pictures from? Just looking to get a feel of whether they show it as it sits at the moment or was it when you bought it?
Old 04-18-2014, 10:05 AM   #16
67-4x4
yes I have the axles and diff cover I don't know why it was opened up well have to ask big rig pardo that's who I got it off of a couple of weeks ago pictures from me were taken the other day when I sent them to you I just met him in gettysburgh on the 29th of march we traded some money and a longhorn rollin frame and bed well have to get ahold of him and see why it was oponed up it didn't matter to me cause I was gona go thru it
Old 04-18-2014, 12:06 PM   #17
Dale_Brown
67-4X4
Please consider me next in line, or if you are willing to part out, your plan "B" for the bell housing 4sp trans, transfer case, drive shafts, cross member, and clutch linkage.
I can pick up May 9, 2014
Old 04-19-2014, 06:27 AM   #18
I can pretty well guess why the differential cover and an axle would be pulled. Still haven't lost interest. I'm sending an e-mail.
Old 04-19-2014, 07:44 AM   #19
67-4x4
tim I can pull the bag off of that rear diff and take a look did you get ahold of bigrigpardo maybe he can tell us that but I can look in there and see how it lokks
Old 04-19-2014, 08:16 AM   #20
No,I haven't yet. The cover doesn't concern me. Could have been checking for ratio. But,both that and axle shaft leads me in another direction...especially with neither being put back together. I'll keep my thoughts out of the thread since they aren't a proven fact. I just sent an e-mail. Gotta get going to work and will check your reply this evening.
Old 04-19-2014, 11:33 AM   #21
bigrigpardo
dan dan da. ok its back story time. the guy I got the truck from bought it in 2007 and drove it for 2 years when the rear wheel cylinders gave out and he was putting fluid in every day. so he pulled it apart but got into a bad car accident later that week and really screwed him up bad so it sat all pulled apart as he was going to change the fluid brakes and do a reseal. it sat completely disassembled for a few years but the drums bearings axles and all hardware were safe and inside. when I bought it I put the drums and bearings on to roll it on the trailer and get it home. and then made the deal with jim. so neither of us felt the need to put it together right away. he has everything to put it together except new shoes and wheel cylinders. all the hardware is bagged and tagged for the most part and I went through and counted and it seemed everything was there. I have been in an ho52 a number of times so I knew what I was looking at. he also had a beautiful 72 blazed in med bronze with a black top. but he wanted 10 grand and that was a little out of my price range.
Old 04-19-2014, 05:12 PM   #22
67-4x4
Andrew thanks for the reply
Old 04-19-2014, 06:05 PM   #23
bigrigpardo
no problem I am happy to answer any questions you guys have
Old 04-22-2014, 08:34 AM   #24
Dale_Brown
Originally Posted by Dale_Brown View Post
67-4X4
Any thoughts if Special-K doesn't pull the trigger? Would you part out? Carlisle this Friday and I'm hoping to purchase these items. Would rather have yours as the knowledge of working parts is there. Who knows what Carlisle will bring.
Old 04-22-2014, 09:07 AM   #25
67-4x4
special k is thinking of taking it hes gona let me know after carisle I will let you know
