04-15-2014, 10:51 PM | #1 |
1972 GMC 4x4
Parting out a 1972 GMC 3/4 ton 350 / 4 speed / 4x4. 4.11 gear ratio. Parting out complete chassis.
Front and rear spiral shocks $120.00 + shipping $75.00 shipped Complete clutch linkage setup $40.00 + shipping SOLD Power steering pump and brackets $50.00 + shipping SOLD Complete gas pedal / throttle cable assembly $50.00 + shipping Front exhaust hanger $15.00 + shipping $12.50 Shipped Points distributor & coil $25.00 + shipping High hump manual / 4x4 $40.00 + shipping Fan shroud $40.00 + shipping Upper radiator hose pipe $25.00 + shipping Sold Spark plug wire heat shields w/bolts $25.00 + shipping Brake booster assembly with brackets $30.00 + shipping CAN NOT FIND Exhaust manifolds left & right $75.00 + shipping SOLD Rear overload spring set / with hardware $100.00 + shipping $60.00 + shipping Transmission / transfer case cross member $50.00 + shipping Front cross member $25.00 + shipping Front bump stops $10.00 each + shipping Rear bump stops and brackets $12.00 each + shipping Front spring front mount $30.00 each + shipping Front spring rear mount $20.00 each + shipping Left front spring stop $10.00 + shipping Front parking brake cable $20.00 + shipping Last edited by gehrts; 04-30-2014 at 06:06 PM. |
04-15-2014, 11:20 PM | #2 |
Re: 1972 GMC 4x4
Interested in speedometer cable and spark plug wire holders at rear of intake
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
04-15-2014, 11:24 PM | #3 |
Re: 1972 GMC 4x4
Rear spark plug wire holders and speedometer cable $30.00 + shipping.
04-15-2014, 11:28 PM | #4 |
Truckin' Krazy
Re: 1972 GMC 4x4
I'll take the upper metal hose if not completely rusted out, power steering pump & brackets , does that include the pulley too? Pending reasonable shipping to 85207
& how about the front lockout hub assemblies? are they in decent shape? how much shipped with the other stuff Thanks, Tom
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
04-15-2014, 11:44 PM | #5 |
Carpe manana
Re: 1972 GMC 4x4
Cost and condition of the pitman arm shipped to 59901 please.
04-15-2014, 11:48 PM | #6 |
Carpe manana
Re: 1972 GMC 4x4
Also, should be a Dana 60 rear if a GMC but if an Eaton HO52 does it have a posi rear diff?
04-15-2014, 11:51 PM | #7 |
Re: 1972 GMC 4x4
Interestd in the Spark plug wire heat shields w/bolts, can you quote shipping to 66207?
04-15-2014, 11:53 PM | #8 |
Re: 1972 GMC 4x4
I'll take the cable and wire holders also in line on lockouts and shipped price on brake booster assembly to 48817
04-16-2014, 06:03 AM | #9 |
Re: 1972 GMC 4x4
I would be interested in the torque mount for the transfer case (this is the part which bolts to the side of the transfer case and then to the passenger side of the frame). What is the condition and cost shipped to 15701?
04-16-2014, 06:26 AM | #10 |
Re: 1972 GMC 4x4
ill take the shroud if its in good shape , do you have a pic , and ill get in line on front selective hubs
04-16-2014, 06:38 AM | #11 |
One of the First
Re: 1972 GMC 4x4
Interested in locking hubs, a few more pictures and condition description. Thanks
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
04-16-2014, 08:15 AM | #12 |
Re: 1972 GMC 4x4
t korinek, I will get pictures of the upper metal hose to you today. Power steering pump, pulley and brackets are still on the truck. I will get them removed tonight to get a weight for shipping. The front hubs are not for sale. Thanks Mike
04-16-2014, 08:19 AM | #13 |
Re: 1972 GMC 4x4
DeadheadNM
I will inspect the pitman arm tonight and send you pictures. I should be able to ship the pitman arm in a USPS flat rate envelope, I think. Thanks Mike. |
04-16-2014, 08:22 AM | #14 |
Re: 1972 GMC 4x4
DeadheadNM
I will look at the rear differential tonight. Pretty sure it is the Dana. Doesn't the Eaton have a back cover on the housing, but the carrier comes out the front? Thanks Mike |
04-16-2014, 08:24 AM | #15 |
Re: 1972 GMC 4x4
JeffD72
I will remove the heat shields tonight and get a shipping quote. Thanks Mike |
04-16-2014, 08:27 AM | #16 |
Re: 1972 GMC 4x4
cst204x4
I will remove the spark plug wire holders tonight. The lockouts are not for sale. I will get a shipping price on the brake booster assembly. Thanks Mike. |
04-16-2014, 08:29 AM | #17 |
Re: 1972 GMC 4x4
dodgiesdad
I will inspect the mount and get you pictures tonight. Thanks Mike |
04-16-2014, 08:30 AM | #18 |
Re: 1972 GMC 4x4
undertaker72
I will get you pictures today of the shroud. The hubs are not for sale. Thanks Mike. |
04-16-2014, 08:30 AM | #19 | |
Carpe manana
Re: 1972 GMC 4x4
Yes, unlike the Dana the Eaton rear diff is removed via the front of the axle and has a round cover on the rear.
04-16-2014, 08:31 AM | #20 |
Re: 1972 GMC 4x4
D.PASSMORE
Sorry, the hubs are not for sale. Thanks Mike. |
04-16-2014, 09:18 AM | #21 |
Re: 1972 GMC 4x4
Second in line on the upper radiator pipe..
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
04-16-2014, 09:49 AM | #22 |
Re: 1972 GMC 4x4
I'll take the exhaust manifolds with bolts if $80 shipped to 30005 GA works for you.
Thanks |
04-16-2014, 10:17 AM | #23 |
Re: 1972 GMC 4x4
Front driveshaft to 58045?
04-16-2014, 03:55 PM | #24 |
Re: 1972 GMC 4x4
JimH2828
I will get them weighed and get you a shipping quote. Thanks Mike |
04-16-2014, 03:56 PM | #25 |
Re: 1972 GMC 4x4
BlueMule72
I will get it weighed and get a shipping quote tonight. Thanks Mike. |
