Old 04-16-2014, 10:20 AM   #1
scottv
Anyone removed truck rally wheel center section and welded into a wider wheel shell?
Want to buy a 15x12 inch shell: http://www.speedwaymotors.com/15-Inc...-12,31581.html
Remove center section of a stock 6 lug truck rally and weld into new wider shell.
Anyone done this? Any input? Thanks
scottv is offline   Reply With Quote
Old 04-16-2014, 11:21 AM   #2
mrweld
mrweld's Avatar
Re: Anyone removed truck rally wheel center section and welded into a wider wheel she
I have done several. I use a ziz wheel on a 4 1/2 inch grinder to remove the center. I have a huge welding lathe at work so I put an axle in the lathe and bolt the wheel to the axle so I can indicate the new rim, tack weld several times before welding.
mrweld is offline   Reply With Quote
Old 04-16-2014, 12:50 PM   #3
Keith Seymore
Keith Seymore's Avatar
I use the same technique as Mrweld except I normally make 15x10 wheels.
Lateral and radial runout usually indicates less than .007". I believe the production spec is .015".
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
