Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-18-2014, 01:01 AM   #1
GMCNUT
GMCNUT's Avatar
UBER RARE 1960-61 Chevy Apache V8 engine mounts
Many of you have never seen a set of these, and many of you never knew they even existed, but for the small handful of you who know what they are you also know how crazy rare they are. Like all things not reproduced but highly sought after, these cannot be found anywhere for a "good deal". These are one of those items that are expensive no matter who has them for sale or where you see them posted. So, with that said, this set is for sale for 250.00
If you are thinking you want to build a factory V8 type 60-61 Apache then these are the correct ones you need - you can modify your frame to accept cheaper mounts that are not original if you are going with a 350 V8, or hot rodding - these mounts are for the "purist" going all original and correct.
Shipping is 25.00 anywhere in the continental U.S. - these are larger than they look and made of cast iron and steel so they are also much heavier than you think too - so yeah, it will take 25.00 at a minimum to get them to you....
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 08-18-2014, 10:37 PM   #2
runningiron
runningiron's Avatar
Re: UBER RARE 1960-61 Chevy Apache V8 engine mounts
Those are cool pieces. I have a set on my 1962 BBW Custom cab, factory 283 with a powerglide. I've owned several 60-66 trucks and carryalls and have never seen any of these until I bought my 62.
runningiron is offline   Reply With Quote
Old 08-21-2014, 01:55 AM   #3
1960chevypanel
hey steve it's pat, do you have any 60's gmc clip-type 3/4 ton painted hubcaps?
1960chevypanel is offline   Reply With Quote
Old 08-21-2014, 05:47 AM   #4
1960chevypanel
Looking for 62-63, unrestored
Old 08-21-2014, 10:13 AM   #5
1963c-10
1963c-10's Avatar
PM sent if Steve can't help out....I have 2.
1964 Short bed trailer
Old 08-21-2014, 07:31 PM   #6
GMCNUT
GMCNUT's Avatar
Sorry Pat - dont have any of those. 63 C10 says he has some above though - maybe he can help
Old 10-31-2016, 09:56 AM   #7
padresag
believe that they only came with a/trans
ron
padresag is offline   Reply With Quote
Old 10-31-2016, 10:20 AM   #8
GMCNUT
GMCNUT's Avatar
ron
Glad you said that Ron - I was wondering if this might be the case - I have owned 4 sets of these and every one was on a factory automatic 60-61 truck; the only factory V8 equipped manual transmission trucks I have seen all had the horse-shoe shaped engine mount - so I wondered what the deal was with that and now I understand. I think the radiators and steel fan shrouds are different between the two as well - automatics got a shroud that screws to tabs that are spot welded to the sides of the radiator, and manual trans equipped trucks got the three-ribbed barrel style shroud that bolts to the core support - not to the radiator itself.
Old 10-31-2016, 11:36 AM   #9
Brad54
Brad54's Avatar
The AT radiator was physically bigger than the manual trans radiator; it's a little wider, and a little taller. Same as the 1-ton truck radiators.
It bolts to the regular 1/2-ton core support. I found all this out when I bought a reproduction 1-ton radiator for my '61 Suburban.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
