04-18-2014, 03:29 PM | #1 |
Power steering install question...
So I'm putting power steering on my '67. I have the stuff on the motor figured out. I'm going to get a box for a '78 so it's less turns lock to lock. My question is which pitman arm and rag joint will I need? I'm guessing the rag joint from the '78 but not sure about it or the pitman arm. Any advice is welcome. Thanks.
04-18-2014, 06:34 PM | #2 |
Re: Power steering install question...
I would think '78 rag joint and pitman arm would be your best bet. I just put power steering in my '67 last weekend. I got pump, brackets, and box with pitman arm off the same truck(early 80's I think) and it all bolted up with no problem.
04-18-2014, 07:21 PM | #3 |
Ok thanks. I got the brackets, pump and pulley's from a '67 Camaro.
04-18-2014, 07:33 PM | #4 |
Just finished my 71. Had some parts from an unknown year. Wound up getting new cardone pump from Oreillys, used 71 brackets, single-groove March PS pulley and single groove 71 wp pulley. Collected a single, single add-on, double add-on and triple pulley to make sure I could get it all to line up...It did finally. I have some left over pulleys if youre interested. good Luck!!!!!!!!!!!!!
04-19-2014, 06:49 AM | #5 |
Watch out for your cornhole !
You need the rag joint and pitman arm that fit the year model box you're using.
04-19-2014, 09:46 AM | #6 |
04-19-2014, 10:46 AM | #7 |
did you do a search on the subject?
fyi a 67 will need a dimple in the frame for a ps box.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-19-2014, 03:21 PM | #8 | |
2-The later box mounts flatter with either no need for a dimple or just a little spacing. I wouldn't heat and beat my frame but if necessary I'll spend the $60 and buy the mount from GMC pauls. http://www.gmcpaulstruckparts.com/steering2.htm Thanks for your concerns :-) |
04-20-2014, 10:04 PM | #9 |
[QUOTE=veedubshafer;6636335]1-No I didn't but thanks for the rude remark.
i dont see how askin you if you did a search on the subject is being rude. i was just tryin too help you out.
04-20-2014, 10:14 PM | #10 | |
The Older Generation
That was not a rude remark, it was a simple question.... The later boxes are the same physical size as the earlier ones so it will need a dimple or spacers. LockDoc
04-20-2014, 10:50 PM | #11 |
Your trucks frame needs to be dimpled for sure, not too much for a hammer and a torch.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
04-20-2014, 11:18 PM | #12 |
Ive never seen a camaro steer gearbox on our trucks. If you could, post pics when your done. Id like to see how well it lines up
1967custom |
04-21-2014, 12:23 AM | #13 |
He is using the power steering brackets,pump, and pulley from the Camaro, the steering box is from a 78 c10.
04-21-2014, 11:11 AM | #14 | |
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
04-21-2014, 12:27 PM | #15 |
99% of the questions asked on this board have been asked and answered before. I've researched this subject and many others using the search feature. Instead of being rude and saying "use the search" for an answer, just skip over my question and keep quiet.
As far as heating and beating the frame I won't do that. Spacers of some sort or that kit from GMC Paul's. |
04-21-2014, 12:41 PM | #16 |
Veedub, sorry about the turn of events in this thread. Welcome to the board and I hope you enjoy your stay. Its a very friendly place and not often are there hard feelings. If you have any other questions about your power steering install, you're welcome to PM me. I've done a number of them over the years.
04-21-2014, 04:57 PM | #17 | |
04-21-2014, 07:35 PM | #18 |
I am still working on my ps conversion, I got the pump and brackets off a '74 Nova, and the PS gear from a '70 2wd C10. I had a hard time matching up my pulleys. I ended up buying a 2 groove from Alan Grove Components. It worked out well. You will probably have to cut the fender bracket. I'm currently in te process of rebuilding my steering column. Cheers.
04-21-2014, 08:32 PM | #19 | |
04-21-2014, 10:03 PM | #20 |
Moderator
[quote=midniteblues;6638402]It was not rude at all.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-22-2014, 08:01 AM | #21 |
My 67 had the dimple , and a power steering box , they came in several varieties , manual , power , and my VERY LEAST favorite , power assist . Power assist has something like 12 fitting it can and will leak from , I replaced the power assist in my 68 with a 78 box and am very happy with it .
Also my 68 that had power assist had the dimple
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
