Old 04-18-2014, 11:48 PM   #101
flashed
Re: The "Wrecker"
Also might be interested in seat belts for my 74 if you dont have plans for them .
flashed is offline   Reply With Quote
Old 04-18-2014, 11:52 PM   #102
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: The "Wrecker"
Originally Posted by flashed View Post
That might make it easier to modify(narrow it) if its too wide which I suspect it will be ,but yes Im interested . Let me know what size it is when you have time .
I can do that this weekend or you can come over and see it. The seatbelts aren't good.
Alan's Classic is offline   Reply With Quote
Old 04-19-2014, 06:12 PM   #103
Alan's Classic
Re: The "Wrecker"
John here's a shot of the bed. The deck measures 79.5X109
Old 04-19-2014, 07:21 PM   #104
Alan's Classic
Re: The "Wrecker"
Flatbed eng stamp code CKX. Shows to be a 72, 73, 76 camaro or corvette. 3970010 block cast #. Same block that's in my 65
Old 04-21-2014, 08:38 PM   #105
Alan's Classic
Re: The "Wrecker"
I was crawling around under the 85 flatbed and saw this brake valve. It looks like a sort of progressive proportioning valve. It has the hydraulic line running to it then feeds the rear brakes. It is mounted to the frame and has arm that goes to the axle.
Old 04-21-2014, 08:45 PM   #106
mrolds88
Re: The "Wrecker"
Alan, it is a load sensing valve. Keeps the back wheels from locking up when it's unloaded. Then after a while they go bad and people take them off.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 04-21-2014, 09:16 PM   #107
Alan's Classic
Re: The "Wrecker"
Thank you sir.
Old 04-23-2014, 09:21 PM   #108
Alan's Classic
Re: The "Wrecker"
With Shannon's assistance, tree, chain and come-a-long we slid the flatbed off.
Old 04-24-2014, 12:15 PM   #109
flashed
Re: The "Wrecker"
Alan ,I have not forgotten about the bed ,been busy cutting and splitting firewood but I may have to leave my 1 ton on hold for a while til my budget recovers .
Old 04-28-2014, 10:27 PM   #110
Petie724x4
Re: The "Wrecker"
Subscribed
Petie724x4 is offline   Reply With Quote
Old 05-08-2014, 11:15 PM   #111
Alan's Classic
Re: The "Wrecker"
Cab is off donor.
Old 05-08-2014, 11:24 PM   #112
Bomp
Bomp's Avatar
Re: The "Wrecker"
Let the mayhem begin.
Bomp is offline   Reply With Quote
Old 05-09-2014, 09:28 AM   #113
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: The "Wrecker"
Alan
I might have missed it, but what are your overall plans for the donor? Use the complete chassis and just swap bodies or something else?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-09-2014, 07:31 PM   #114
Alan's Classic
Re: The "Wrecker"
Maybe a little mayhem.
Originally Posted by aggie91 View Post
Alan
I will be using everything except frame, body and bed.
Old 05-22-2014, 10:39 PM   #115
Alan's Classic
Re: The "Wrecker"
The 85 suspension is temporarily hung with a few bolts.
Motor and trans waiting to go in once it gets some paint.
Old 05-23-2014, 09:52 AM   #116
aggie91
aggie91's Avatar
Re: The "Wrecker"
Progress!
Karl
The LST Challenge:
Old 05-23-2014, 12:00 PM   #117
flashed
Re: The "Wrecker"
Alan ,what is the reason for going with the later suspension ,disc brakes Im sure is one ,what else ?
Old 05-23-2014, 05:39 PM   #118
Alan's Classic
Re: The "Wrecker"
Progress!
That's pretty much it. I'm also going to use the hydroboost off the 85
Old 05-23-2014, 06:54 PM   #119
del66
Re: The "Wrecker"
Another advantage is in the future, front suspention parts are for an 85 1 ton, not some special convertion part only made by only one company.
del66 is offline   Reply With Quote
Old 05-30-2014, 11:04 PM   #120
Alan's Classic
Re: The "Wrecker"
I dropped the donor engine/trans in temporarily. I was thinking of making the hydraulic clutch work. The trans mounts are different. The late model trans mount is at tail shaft. The 68 trans mounts are in bell housing. I could have swapped the trans crossmember but then I will have the PTO clearance issue.
I pulled the trans and clutch to inspect. The throw out bearing came out in 3 pieces (not good) and the pilot bearing is toast
I wanted to use the later model engine mounts but it seems to raise the engine up and pushes it back and the trans won't bolt up.
Left over parts
Old 05-31-2014, 07:30 PM   #121
Strodder
Daring to be Different
Strodder's Avatar
Re: The "Wrecker"
Let the fun begins.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 05-31-2014, 10:28 PM   #122
Bomp
Bomp's Avatar
Re: The "Wrecker"
totally diggin on seeing that 3970010 number.
Old 06-01-2014, 07:44 PM   #123
Alan's Classic
Re: The "Wrecker"
Due to life I'm going to stop this project and sell it off as a lot or part out.
Old 06-01-2014, 08:04 PM   #124
flashed
Re: The "Wrecker"
WOW Alan ,sorry to hear this ,hope all is well.
Old 06-01-2014, 08:49 PM   #125
McMurphy
McMurphy's Avatar
Re: The "Wrecker"
Wow man, I saw this announcement on FB today, this is equally sad as it is sudden.
I hope all is well, in this day and age it is hard not to imagine the worst though.....
Rock on buddy, what ever you turn your hand to next will be outstanding I am sure !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
