04-02-2014, 07:44 AM | #1551 |
Re: Not Another Rebuild Thread....
Like this one way better Murph.
May take a time or two (me its usually 3-7 times) but in the end its something to be proud of. Diggin it |
04-02-2014, 08:33 AM | #1552 |
Got to do a Ta2Don for this one. Pizza box engineering. Making so many projects come out right. Well done.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-02-2014, 10:26 PM | #1553 |
dam that pizza place must love you lol
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
04-02-2014, 11:09 PM | #1554 |
Pizza Box Engineering...
Full Belly = Better Brain Power...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
04-02-2014, 11:50 PM | #1555 | ||
Thanks Modges, I was thinking of you today as I flipped that rear ANTI-sway bar. Thanks again for pointing that out.
It is a mutual love triangle... they love me, I love them, and I love pizza !! Probably something to that Don..... ****************************************************************************************** Just a quick update on the hood latch pattern/template. In my fiddling with it I noticed it tended to rub a bit on the base plate, so today I modified it with a 1/4" cut which you will see in the photo below. It angles in from the mounting bases and on the pizza box cuts out the numbering for the overall lenght of the template. I also welded in a MUCH thicker plate on the plunger-latch rod end in an attempt to keep this from warping. I wish I had made it of some thicker sheet metal, but I did the best with what I had around. Anyways today was a good day, chased down a turn signal ghost, flipped the rear ANTI-sway bar, mocked up my front bumper for consideration, and started laying bed frame cross members, taking note of what I need to get from the hardware store tomorrow. Hope you all had a great mid week as well
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-13-2014, 02:34 PM | #1556 |
As you guys may have guessed I have been busy plugging away on my build, just not a lot of things to really share.
Chased down that turn signal gremlin that turned out to be the brass contacts in the actuator switch in the column. Fixed a fuel supply issue that was keeping me from running the engine for more than a few seconds. Figured out, and wired up my tail light needs for when I get to that point so it will be all done. With my intended use of the Caddilac lights, I determined that I would need a relay wired in for the back up lights to work since they do not activate off the ground switch off the transmission. Front fenders are hung now too, with the splash guards in to protect the head light assemblies. I also got my fuel fill and fuel door figured out to the point where I can do final assembly on it when I get all the surrounding bed concepts worked through. After all that it was time to address the bed. The nice thing about having multiple items to work on to get a section done, is that there is a part or panel to work on as paint or bondo are setting up on another piece. I like this as it exersizes my multi-tasking skills and I dont hit any brick walls because I absolutely need the part I am working on in order to progress. On the list is to shave my stake pockets, cap the bed rail ends, minor side board patching, and shave the rear signal mounts in the fenders. On the custom end, I am going to add an extension to the steps, totally customize my tail gate (teaser on that one), and fab up a roll pan to mount my tail lights into. So far: I made a Dolly for this, and wish I had made it sooner for other places, but this is my hole after a little hammer and dolly work: Now the patch: I will have more pics later, I left the camera down in the garage last night, so more to follow guys !!
04-13-2014, 02:50 PM | #1557 |
Updates...
04-13-2014, 03:22 PM | #1558 |
wow... you're making some great headway. dreaming up ideas and solving problems as you go. thataboy murph!
04-14-2014, 10:27 AM | #1559 |
ah that is a teaser on the tailgate lol..where are the caddy lights going to mount
04-14-2014, 02:20 PM | #1560 |
Thanks guys, but I have to re-do those fender patches; I really goofed them up. I was trying to cut conservatively, but now realize I need to whack out a much larger space for them to look right.... more to follow on that mess.
Pirate this is how I have them mocked up at this time: I am contemplating some pretty special plans for them. When it is all said and done, they should be fairly slick.
04-14-2014, 02:49 PM | #1561 |
At my fave junk yard there is a 60-64 GMC long step, big back window that had the cab trim. Not sure if I am going to use it, but I pulled the trim pieces anyways, even though of the 4 pieces, one of them was pretty munched.
I brought them home, and in a fit of indulgence, I worked with the munched drivers side piece. Although it is far from perfect, I dont think I would be too ashamed to mount it up and run with it until I could find a replacement! Here it is BEFORE: And AFTER: For these photo purposes, I did not do anything to the p-side trim. If I had just a tad more patience, and better polishing equipment, I think I could make that mangled one look even better.
04-14-2014, 02:49 PM | #1562 |
Nice job....waiting to watch the taillight mods.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
04-14-2014, 11:49 PM | #1563 |
Senior Enthusiast
Nice improvement. It's tedious working with straightening and polishing stainless, but the results can be a great reward.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-15-2014, 08:24 AM | #1564 |
Good Progress!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
04-15-2014, 06:39 PM | #1565 |
Glad to see you busy on the truck Murph! Trim is always cool
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
04-15-2014, 08:25 PM | #1566 |
Taillight Mock-up...
The trim is looking good, patience Grasshopper!!! Great Work Murph!!!
04-16-2014, 12:30 AM | #1567 |
Looking at the price of a full set of trim pieces for my Short Fleetside landed here in the UK vs your results so far, I am wondering if repairing or having mine repaired, as every piece is damaged, does not make some sense, especially if I could find an old skool craftsman to involve.
I have been looking to find you a set of old London Taxi Cab rear lights like I have on the teardrop trailer for months now, just to mess with your head but have not been successful ( yet )
04-19-2014, 01:43 PM | #1568 | |||
Well then this post is for you bud, see below !! Probably not what you are looking for just yet, but there are about 5-8 related parts or sections that are coming into play for this mod, so please be patient. In the end, just like my grille, it should all make sense.... or it will be an epic fail. We will see.
Thanks Low, I sure do like looking at your build too sir !! Thank you, like I just told Mark, not even sure I am going to use it, but it is there, lurking in the back of my mind.... Quote:
******************************************************************************************* Ok kids, here we go... Like I said previously, I was not happy at all with the initial shave job I did on those rear tail light spots on my fenders. So, back at it went I... They look pretty rough here, but we ran out of our spool of .30 wire which I was REALLY starting to like better than the smaller .23. For me I was laying better welds with lower heat with the bigger wire, and it seemed to be less time consuming to weld stuff, so this chore got to be tedious very quickly; aside from the fact that it was a re-do... I had to go with much bigger patch panels than I originally anticipated to take as much of the factory contours out of play as possible, which I discovered were more than what initially meets the eye... I also used more bondo on this than I have any other mod or project I have done. Not so much to asuage my disappointment, but to get as close to a professional looking job as possible, without spending a week on this one project. I think they turned out pretty good: As smooth as a baby's butt: Here is what I finally settled with, though props to Alan and all you other pro-body working guys for the info and guidance you provide !! I am certain however that my amature status is in no danger of being upgraded any time soon LoL !!! Thanks for looking dudes !!
04-19-2014, 01:50 PM | #1569 |
I do like to provide never before seen images and concepts, so here we go again.
How about an exploded view of a step side tail gate? TaaDaa: This one is for all you guys that are itching over what my tail gate mod is going, or maybe, going to be... As stated in my post above, this is one of the 5-8 parts or sections that are coming into play for my tail light mods... I know that is so ambigous to tell you all, but like the grille, it will all make sense in the end. Well, maybe a certain amount of McMurphy sense, is a better way to turn that phrase.... Enjoy !!
04-19-2014, 02:44 PM | #1570 |
Rollin' Old Skool
Nice job on the fender patches Murph. Look forward to seeing your idea come to life for the Caddy taillights & tailgate!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-19-2014, 06:31 PM | #1571 |
Senior Enthusiast
I agree. To the unknowing, those look like non-back up light factory fenders. Nice work!
04-19-2014, 11:39 PM | #1572 |
Nice work on the fenders bud, looking forward to seeing what you have in store for the tail gate!
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
04-20-2014, 12:32 AM | #1573 |
Thanks for the compliment, "Epitome" of your fan base… Not really sure if I deserve that one… there are more than a few members here that look in on you as much or more than I do… but I'll remain humble as I say thanks...
Well played on the Fenders... and I know what you mean about those factory contours... My tail-light buckets will be on the finished list this weekend,,, I have a long day planned for tomorrow, and if all goes well, plenty of updates finally!!! …and I must admit, the tailgate mods truly have me guessing... GREAT Work!!!
04-20-2014, 12:26 PM | #1574 |
well as i see it , red led lights in the letters ..just my 2 cents
04-20-2014, 01:55 PM | #1575 | |||||
Going to whip up some stuffed crepes for the wife, then down to the garage go I.... see you all laters !!
