1/4 Scale Model T Firetruck Go Kart Project
We started on this project about two months ago. It was built pretty cheaply and had all hand controls- throttle/brakes/clutch. The owner wanted it updated with normal foot brakes/throttle, and electric start engine, and wanted the body/frame restored. He also wants working lights, a bell, engine cover, ladders, hose reel, and a tail board on the back.
Here's a cart we borrowed for reference that was made by the same company. It's newer than the one we are restoring and has some updates already. ![]() And this is the one we'll be restoring. I forgot to get good overall shots. ![]() ![]() Wood spoke wheels. ![]() 3hp Briggs engine, hand operated belt drive. ![]() Fenders are fiberglass and are in rough shape. We've found NOS boards and they're supposed to ship today. ![]() Tin can "headlights" that will be replaced with chrome housings with 4" clear H3 fog lights. ![]() Hand throttle. ![]() The "grill" was painted dots. We'll make a real grill insert. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: 1/4 Scale Model T Firetruck Go Kart Project
After tear down, blasting the body panels, and prepping the panels for high build primer.
![]() We built a new rear cab panel to make it a single seater. The hump in the back rest made it pretty uncomfortable for anyone over 7 years old. ![]() Electric start Honda GX160 engine. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 07-14-2014 at 04:16 PM. |
Grill opening cut out.
![]() Stainless mesh for the grill insert. ![]() Insert backed with a piece of steel painted flat black. ![]() Assembled in the grill. We'll have the grill surround nickel plated. ![]() Building a new frame from 1.25 x .125 wall square tubing. The old frame was too far gone to reuse, and it was less work to start fresh instead of modifying the old frame. The old frame was angle iron so it was a lot weaker too. ![]() The original wheels were wood spoke and they wouldn't have held up to the bigger engine for long. We found a source for aluminum spoke wheels that bolt to kart hubs that will work perfectly. The casting texture was uneven so we sprayed a light/dry coat of SEM Texture Coating to even out the surface. They'll be painted a medium cast color, with a polished rim and center hub. ![]() ![]() Made tubular steel suspension pieces for the steering and front axle radius rods using .058" DOM tubing and weld in rod ends with L/R hand chromoly heim joints. ![]() ![]()
Hydraulic disc brake parts.
![]() ![]() New smooth rear cab panel. ![]() New floor pan. ![]() Made a curved headlight bar. It's hollow tube so we can hide the wires inside it. ![]() Test color/texture for the wheels. ![]() 5" chrome fog lights to use as the headlights. We bought 3 watt LED bulbs to keep the strain on the battery to a minimum. ![]()
Been awhile since I updated this. Got the body/frame painted and assembled. Dad is going to do the upholstery next. We have lengthened the stock engine wiring harness and separated the switch from the original switch box. Still a ton of little details to address before it's finished.
![]() ![]() Nickel plated grill shell with polished stainless mesh insert. ![]() We mounted the engine and axle on a cradle so it can all be removed easily. The only things that will have to be disconnected are the gas/brake linkage rods and the wiring harness. ![]() Body was assembled with polished stainless button head bolts. ![]() Solid axle, lightweight sprocket, slotted brake rotor, and braided stainless brake flex hose. Can't talk the owner into 8" wide kart slicks! ![]() ![]()
2WD Jimmy
![]() Join Date: Mar 2005
Wow.
KEEP ON TRUCKIN'
![]() Join Date: Jun 2005
Thats awesome. Should be a real head turner driving that around.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 ![]() http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" ![]() |
Very nice ,I like it.
![]() Join Date: Nov 2004
Do y'all do anything that isn't incredibly awesome?
Love it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#10 | |
Wow. At this point you shoulda stretched the wheelbase and put a Chevy small block in it...
![]() Seriously though, Looks great! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
That's tight! I'd have to have mine slammed on turf tires in the back. Too cool.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
Pretty much finished with the headlight bar. Its hollow so the wires will be hidden inside. I notched the stem of the headlights so the wires can go through the side of the stem instead of out the bottom. I'll use a chrome acorn nut and washer on the bottom for more of a finished look. The bar will be nickel plated to match the grill.
![]() ![]() The owner decided that he wanted a truck bed for it so I made a cardboard template to check the size and proportions. It looks a little long in the picture but it's actually shorter than the original Model T beds. I made a shorter version but it didn't "fit" so I kept adding to the length until we all agreed on it. ![]()
#15 |
![]() Join Date: Aug 2004
I like the pickup bed better than the car.....but I am also biased.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#16 |
That thing is awesome!
Where to start? |
#17 | |
![]() The title of the thread is "model T firetruck" ! Love the headlight bar!
#18 | ||
Thanks! Quote:
Thanks, the headlight bar is off to the chrome shop to be nickel plated to match the grill.
#19 |
That is coming out really good! I have one just like it
#20 |
#21 |
![]() Join Date: Aug 2007
Beautiful work!
Scotts72C10 |
