Old 04-23-2014, 11:19 AM   #1
no_rice
help with power steering swap
ok... so im trying tpo put power steering on my 70 GMC. its a short water pump setup. i thought a pump/steeringbox i bought awhile ago was for a short pump arrangement, but obviously something is wrong.
i have spent a fair amount of time searching around for info on this and have read alot of stuff, but probably through some fault of my own i have not come up with a good solution.
ive seen people use a 3 groove crank pulley and an offset 1 or 2 grove PS pulley in some configurations. maybe thats what i need to try to locate?(looked into it some but havent come up with them)
you can see how far off my pulley is from ANYTHING.
this shows the bracket i have a little better. there doesnt seem to be a difference between the pump itself regardless of short or long water pump?!
this is the setup on my 70 c10 parts truck, which has the long water pump.
any help would be appreciated as im getting frustrated. heck i fell asleep infront of the truck in the damn garage last night searching info on this at about 1am... lol. im trying to get this thing together before next weekend... ugh.
no_rice is offline   Reply With Quote
Old 04-23-2014, 11:56 AM   #2
no_rice
Re: help with power steering swap
possibly found one piece
second pic down lists an add on 3rd grove(says it is usable with single or dual grove crank pulleys) supposedly for short pumps with power steering
http://www.alangrovecomponents.com/i...outings_SP.pdf
even if that is right, i still appear to need to come up with an offset PS pulley...
Old 04-23-2014, 12:07 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
This is the correct pulley you need. It's the factory GM part off of a P/S truck with short pump.
With that pulley stacked onto your current lower pulley, your P/S pulley will line up properly without any further mods.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-23-2014, 12:23 PM   #4
no_rice
im guessing that is a different part then the gm part #3751232 they had listed in the link? if so, any ideas where i can come up with one?
thanks for the response!
Old 04-23-2014, 01:36 PM   #5
no_rice
hope this is the right one, because its on the way...
http://www.ebay.com/itm/GENUINE-GM-3...item258b6afb1a
Old 04-23-2014, 01:38 PM   #6
Tx Firefighter
I do believe you're in business with that one.
