OEM Bedrails - Missing Fasteners!
Does anybody have a clue where to find the fasteners for the OEM bedrails on my '85?
They're a 1/4"-20 x 7/8" stainless steel machine screw but the trick is: it's a countersunk oval torx head that's only .375" O.D. (most 1/4"-20 screws will have a .410 - .430 O.D. head that will not fit in the pockets of the bedrail stand-offs). I've been looking and you wouldn't believe how hard it is to get a screw with a little head! I think an Allen cap-screw will fit but... no countersink so it's not going to bottom properly in the pocket and, as it's stainless on aluminum, it will eventually grind it's way all the way through the stand-off. Maybe a better compromise might be an oval Phillips head turned down a bit in a lathe or on a grinder Any thoughts?
1985 GMC K2500 Sierra Classic / 350cid / TH400 Auto |
Re: OEM Bedrails - Missing Fasteners!
good luck! just find something close and make it closer on a lathe
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
See if you could find some at scrap yard?
1979 ![]() 1996 Silverado x-cab "the daily" |
Is the attached picture what you're looking for? If so, you can probably find them in a junkyard but the trick is to look for a Suburban roof rack rather than a bed rail (which I've never seen at a pick-and-pull). The length is just a tad longer than 7/8 and the head is 0.365 rather than 0.375, but maybe they'll work anyway, eh?
You might have to check more than one Suburban - not all that I looked at were dealer installed. Many were poorly installed or repaired with crappy self-tapping sheet metal screws but the factory/dealer ones used the T-20 torx bolts into well nuts.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
Score!
Thanks SilverMiner!
![]() Join Date: Jun 2009
I have seen some of the earlier factory bed rails with phillips heads. I don't think GM started using torx until 1978 or 1979 on anything.
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
