Old 04-25-2014, 09:24 PM   #901
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by brimc View Post
Looking real good. What are you spraying on the axles for black paint? I tried some tremclad at first and had rust bleed in only a year sitting in the garage.
Thanks!
its just rustoleum enamel. normal stuff from a plain white can. where i live, it could go a thousand years with no paint and still only have surface rust. i would have considered heavier coating, possibly even PCing if i still lived in the rust belt.
Originally Posted by Dieselwrencher View Post
Looking nice Ryan. Just reshoot the missed areas. I'm surprised it's glossy.
Thanks! i got some black on it, im sure i missed it somewhere else though... flash photography will expose my inadequacies later i am sure. its semi gloss, so far anything black on this truck has been. just a little more shine than flat, but not full out! No gloss in this joint!
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 04-25-2014, 10:02 PM   #902
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
I'm having a beer to celebrate your accomplishments!
Old 04-26-2014, 06:30 PM   #903
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Have two Pete! i got some more done today.
paint was dry enough to assemble.
ran a tap through the threads to get the last of the dirt that was leftover.
put the kingpins back together and installed the steering arm with ARP studs and fresh nuts. it looks like i missed a lot of paint, but its the strap reflecting off the black.
you can see the fresh stover nuts on the spindles. i have never heard of any news headlines caused by reusing mechanical style lock nuts, but i got a bag of 50 for less than ten bucks so i replaced them.
also intstalled the hubs with the fresh studs. havent decided what i am doing for brake rotors yet and i need to clean and paint the abutments before i install them anyway so i left them all off. you can see the bolt in the bracket that holds the abutment. in order to keep the best thread engagement i installed them first so i would not need to make them shorter in order to install while the bracket is bolted to the knuckle.
put the cover on temporarily for now. i think i will order a lubelocker gasket for it. used button head bolts, since, because. i think i will order new lower and upper kingpin cap bolts. i need to order my new lower pin plates and install them as well.
i commited to the plan and drilled my knuckles. i stole the tie rod from the other axle and put it on so it will roll somewhat. i need to order the tie rod ends and tube to put the correct tie rod on this one and put this one back on the other axle before it dissapears
72 K20 12v build
Old 04-29-2014, 08:23 PM   #904
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Some more tidbits of fun.
a hone job
then a wash
nice and clean, back on the stand. oiled the bores and the mains. hope to drop the pistons back in soon.
made up a filter mount bracket. now i just have to figure out if i can get it mounted the way i want and have space for the plumbing. not positive how i am going to deal with that just yet.
and then...
72 K20 12v build
Old 04-29-2014, 08:59 PM   #905
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Re: 72 k20 project
Looking great!!!!!!
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 04-30-2014, 12:22 AM   #906
84chevyguyid
Re: 72 k20 project
That cab looks sweet!!
84chevyguyid is offline   Reply With Quote
Old 04-30-2014, 12:24 AM   #907
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k20 project
Downhill from here on out I'd say!
Old 04-30-2014, 10:11 AM   #908
brimc
brimc's Avatar
Re: 72 k20 project
Looks great
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 04-30-2014, 05:10 PM   #909
mx289
mx289's Avatar
Re: 72 k20 project
I need that cab !
Looks great Ryan.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 04-30-2014, 06:48 PM   #910
6BT 56
6BT 56's Avatar
Re: 72 k20 project
Love that colour . Is that blue or green or what ? Looks close to what my 56 was new .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 04-30-2014, 06:59 PM   #911
sboris
sboris's Avatar
Re: 72 k20 project
Cool color Ryan.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 04-30-2014, 09:12 PM   #912
swamp rat
swamp rat's Avatar
Re: 72 k20 project
That cab is to die for! What is the color code?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-30-2014, 10:13 PM   #913
Mustard72
Mustard72's Avatar
Re: 72 k20 project
Shweet!
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 04-30-2014, 10:34 PM   #914
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Originally Posted by Vintage Windmills View Post
Looking great!!!!!!
Looks great
Thanks! i was pretty excited to see it. first time its had any real color in a while
Its rolling good right now, hope i can keep up the momentum.
Originally Posted by mx289 View Post
I need that cab !
Looks great Ryan.
Thanks! and you'd have to fight me for it... ive been waiting for that for the last 16 years!
Gm called it green, i call it mint or seafoam when i try to explain it.
Originally Posted by sboris View Post
Cool color Ryan.
Thanks. i used to hate the color, but now i really love it
518 medium green. it is the original color for the truck, just looks really bright now since it hasnt had any sun fade. i was excited to see the pics, i was standing in my living room dealing with a sewer back up when the painter sent them to me. perfect timing
Originally Posted by Mustard72 View Post
Shweet!
Thanks!
72 K20 12v build
Old 04-30-2014, 10:41 PM   #915
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Todays progress.
got the crank washed and rolled the new shells in. crank back in and mains torqued. spins like a top.
we also got the new rings in the pistons and re-assembled the pistons and rods. hope to slide them back in the holes tomorrow. i ordered a set of studs for the head that have arrived as well. as long as the head checks out, i should have all the needed parts for the engine. after some talking i think we are going to send the pump to a friend of my buddy Sean's. Sean is a bosch pump guy but lacks all the fancy tools his buddy has. so for a nominal fee, the pump will get the dope treatment. i need to start working on my oil pan soon as well
72 K20 12v build
Old 05-01-2014, 05:28 PM   #916
mx289
mx289's Avatar
Re: 72 k20 project
Ok then.
But i must tell you,I was trained by John Rambo in street fighting.
Motor is looking good.
Tom
71 K2500
71 K5 Jimmy
Old 05-01-2014, 07:11 PM   #917
6BT 56
6BT 56's Avatar
Re: 72 k20 project
Looking good . Soon it will be ready for a coat of detroit green to blend in with the orriginal colours on the rest of the truck !
Old 05-01-2014, 07:32 PM   #918
superduty_59
Re: 72 k20 project
Ryanroo love the build so far. Took me a few days at work to read your thread. You have crazy good skills at fabricating. Excellent choice of truck and engine. Love the color! I'd like to see a video of you truck driving by this summer!
superduty_59 is offline   Reply With Quote
Old 05-01-2014, 09:19 PM   #919
ryanroo
ryanroo's Avatar
Re: 72 k20 project
Ok then.
Thanks! i learned from John McClaine. this aught to be a solid battle... haha
Looking good . Soon it will be ready for a coat of detroit green to blend in with the original colours on the rest of the truck !
Um.. ive been trying to avoid oil leaks, so i dont know about that... HAHA paint should be coming soon hopefully
Thanks! i hope to make bad air this summer too, but who knows. i cant make any promises... after the transmission gets a refurb, the driveline is pretty much done. at that point i should be able to make it move.
Todays work
The gear housing and cam are back on/in as well. phone died before i could take the end of the session pic.
i grabbed this box, as we are getting close to needing it. i didn't realize that the pedestals required machine work... i guess i know what i am doing tomorrow.
i also started another garage furniture project. despite the fact that my garage is already to small, i really want a heavy table to work on. here is the pile of steel, ready to be glued together.
3'x4'x.75" plate top. 3" tubular legs and assorted sizes of angle iron(GASP!) to construct the frame.
72 K20 12v build
Old 05-05-2014, 07:18 PM   #920
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 72 k20 project
That cab looks sweet, and the engine is coming along nicely too! That fab table sure will come in handy!
Ryan
1969 Chevy milk truck
Old 05-07-2014, 10:52 PM   #921
ryanroo
ryanroo's Avatar
Re: 72 k20 project
the rebuild is essentially done. painted black, of course.
the cab found its way home, but i need to get about 1000 other things done before i sit it back on the frame. so i have to cover it and be careful
72 K20 12v build
Old 05-07-2014, 11:02 PM   #922
jbclassix
Junk Yartist
jbclassix's Avatar
Re: 72 k20 project
Slightly jealous.
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-08-2014, 04:16 PM   #923
Dieselwrencher
Re: 72 k20 project
Looks great. Have you decide on if the stock pan will work, or is it still going to be a custom aluminum one? (I hope aluminum one because that will be BA.)
Ryan
Old 05-08-2014, 05:00 PM   #924
Mattman2010
Mattman2010's Avatar
Re: 72 k20 project
Looking good Riley!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 05-08-2014, 05:11 PM   #925
mx289
mx289's Avatar
Re: 72 k20 project
Nice. That was a quick rebuild !
And trained by McClaine huh ? Lets do this !
(This will sound very random,but my mother actually went to HS with him.No BS.
Said he was very quite.)
And take care of that cab.Or i will show up with a viking and take it.
Tom
71 K2500
71 K5 Jimmy
