Old 04-27-2014, 10:36 PM   #1
emil77
'72 Chevy C20, cracked wheel?
Hi guys,
While driving my '72 Chevy C20 today, I noticed a crack in the right front wheel. Is there anything I can buy to "fill" the crack, or do I have to buy a new wheel? Is this something to be worried about?
I am not sure about the size, the tires say 9.50r16.5lt. If I do need to buy new wheels, any tips/locations for buying one? I live near Los Angeles, CA, zip code 91042.
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 04-27-2014, 11:07 PM   #2
undertaker72
undertaker72's Avatar
Re: '72 Chevy C20, cracked wheel?
I think that is a seam in the wheel band process, you can also see it thru the window in your spoke , I imagine it goes from one side to the other , the cheaper wheelsroll ther band and weld a hub or wagon wheel spoke assy to the band , I would almost bet your others have similar marks
undertaker72 is offline   Reply With Quote
Old 04-28-2014, 10:12 AM   #3
71Dually
71Dually's Avatar
Yep, looks like it could be a seam. If it is in fact a crack replace the wheel.
Appears you have tubeless tires, in that area of the wheel a crack will leak air. Use a soapy water solution to check for leaks.
If it were my wheel and leaked air I would immediately replace the wheel to prevent failure. An air leak in a wheel indicates imminent wheel failure.
Both LKQ Pick-A-Part and Adlen Brothers Pick-Your-Part in Sun Valley are a source for used wheels. There are also vendors in the parking lots in both locations that have wheels and tires. These vendors usually get an early pick on all the used wheels and tires when they are set in the yard and would know which used wheels are serviceable and safe to sell. Those would be the wheels they have for sale.
1971 Chevy C30 Custom Camper Cab Chassis Dually 402 TH400 4.10:1 Eaton HO72
1969 Ford Mustang "Mach 1" 428CJ 4 speed "R Code"
1970 Mercury Cougar "Eliminator" 351C-4V C6
1972 Ford Ranchero GT 351C-2V C6
1974 Honda XL-350
Member of the "6 C's and a D" 1-Ton Fun Club!
71Dually is offline   Reply With Quote
Old 04-28-2014, 10:30 AM   #4
undertaker72
if you need a 16.5 white spoke I have about 5 sets , glad to sell you one 25.00 plus freight
Old 04-28-2014, 12:08 PM   #5
emil77
Are those vendors there 7 days a week? Will they be able to change the wheel also or I have to go elsewhere?
Awesome, thanks. But I am not sure of the size of the wheel. That's the part I am confused. I know it's a 16.5 tire, but what about the offset of the wheel?
Thanks,
Emil
1972 Chevy C20
Old 04-28-2014, 05:50 PM   #6
71Dually
71Dually's Avatar
Yes, they are there pretty much open every day I believe. Every time I go to those yards the tire shops are open for business. They do have the ability to do all tire service work.
1974 Honda XL-350
