04-28-2014, 11:44 AM | #1 |
Junior Member
Need help deciding suspension set up and Porterbuilt Dropmember
I am looking for some info on suspension for my 68 Chevy. I am currently in the planning, parts ordering, and teardown phase of my build. I see you porterbuilt offer 3 different front drop members. My goal is to go as low as possible on air, I would like to lay frame, however I would also like to keep a stock bed floor.
From what I have read that is not possible. So what is recommend to get me as low as possible front and rear while maintaining a stock rear bed floor? I would like a complete front kit including, brakes, spindles, steering rack and all. I am trying to build this on as tight of budget as possible and with everything I want to do I need to stretch my dollar as far as possible, so I ma loooking more for the necessity's. As for the rear, what are my options to compliment the front? Can I modify the stock trailing arm setup and still get low or what do you guys suggest? |
04-28-2014, 12:05 PM | #2 | |
Re: Need help deciding suspension set up and Porterbuilt Dropmember
If you want to keep the bed floor unmolested then you only have one option. A Stage 2 Rear. There are a couple configurations of the Stage 2 rear that will yield the same stance, but have different components. Up front you can keep the factory x-member and run our Stage 2 front kit. Again, a couple variations depending on how fancy you want to get. Or if you want to go all out up front, you can run one of our Dropmember Mild front kits to replace the factory unit. Feel free to send us an email for a price quote. Sales@pbfab.com Nate
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
04-28-2014, 12:06 PM | #3 |
67-72 parts collector,…
A standard 7" double convoluted air bag compresses to about 3".
You can remove your springs and add a 3" block in it's place to see how low you can go with just a standard "bags replacing springs" set-up. The rear can go a little lower with the addition of a bolt-in c-notch and a 2" lowering block. But that's it. The center section of the rearend will hit the bed floor, and the front crossmember will be on the ground (with cupped stock a-arms or aftermarket a-arms) and the inner fenders removed. But the frame will not be laying out. There are MANY threads on here titled "how low can I go". Each thread has lots of pictures.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-28-2014 at 12:12 PM. |
04-28-2014, 12:08 PM | #4 |
Here's a good thread to look at:
http://67-72chevytrucks.com/vboard/s...d.php?t=575686
04-28-2014, 12:10 PM | #5 |
Also look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=609897
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-28-2014 at 12:15 PM. |
04-28-2014, 01:34 PM | #6 | |
04-28-2014, 02:01 PM | #7 | |
Junior Member
I really want the in the weeds laid out on the rails look, but I just don't know that I am going to have the budget to take it that far right now. I was thinking of doing the full front c-member and everything now while I have it all apart and then maybe a few years down the road I can redo the rear to get it all the way laid out... |
04-28-2014, 02:02 PM | #8 |
Junior Member
double post
