04-25-2014, 06:38 PM | #26 |
Re: 66 bagged CREW CAB CHOPPED TOP shortened bed
Used tape to mark out 4"
04-25-2014, 06:48 PM | #27 |
Welded the posts back together
04-25-2014, 06:48 PM | #28 |
And then it was chopped
04-25-2014, 06:51 PM | #29 |
To weld the rear corners of the can I had to squeez and stretch so relief cut from my grinder took care of that.
04-25-2014, 06:52 PM | #30 |
After I welded it up
04-25-2014, 06:54 PM | #31 |
Sizing up the notch
04-25-2014, 07:00 PM | #32 |
And cut it up.
04-25-2014, 07:02 PM | #33 |
Reinforced it and bagged it after that of course.
04-25-2014, 07:05 PM | #34 |
Stayed this way for a while. Got tired of working on it. So took a break.
04-25-2014, 07:08 PM | #35 |
Forgot this one. Trimmed the front cab too.
04-25-2014, 10:17 PM | #36 |
Pulling the donor cab
04-25-2014, 10:25 PM | #37 |
I didn't take any pictures of changing the front frame to the subframe of a camero. Should have but. Oh well. But yea I changed it out to the camero front clip and rear differential. The rear is a disc brake limited slip 3:73. I also used the 305 HO and the 700r4 from the camero. Not looking for huge power. Just enough to get it down the road. The interior is still cut up. Still have a lot to do.
04-28-2014, 04:35 PM | #38 |
Here's the pic I saw in a truckin magazine. I was stuck on it and had to build it.
04-29-2014, 05:27 AM | #39 |
65 suburban vortec 5.3 bagged
very cool!!!
04-29-2014, 05:53 AM | #40 |
Loving this!
My old truck: '66 Shortbed Stepside - Ex USAF - Shiny and new on the inside & underside, original patina on the outside. - http://67-72chevytrucks.com/vboard/s...d.php?t=487701 Tattooed pinstriper and graphic designer with an awesome award winning beard! Check me out at http://www.vontash.co.uk |
04-29-2014, 12:53 PM | #41 |
C10 CLUB Y QUE!
good job!
05-03-2014, 12:17 AM | #42 |
1961 crewcab
looks cool, what year Camaro parts did you use?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-03-2014, 12:24 AM | #43 |
Radiator, front sub frame "clip" disc brake rear end, motor tranny steering colom, brake pedal n booster. The clip was out of an older camaro but everything else is 1984. I still have a lot to do but no time to do it.
05-03-2014, 06:51 AM | #44 |
Welcome Gonna watch this build for sure. defiantly nailed the proportions.
05-05-2014, 01:32 PM | #45 |
Awesome looking truck!!
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
05-05-2014, 07:27 PM | #46 |
chevy only
aton of cool work kat
CHEVY ONLY... Nothin Else ! |
05-08-2014, 11:39 AM | #47 |
Chopped Top and Crew Cab!!!
Very Nice!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
05-11-2014, 10:23 AM | #48 |
Wow, talk about a pile of work. Will be watching tell its finished
02-06-2015, 03:32 PM | #49 |
I'm getting motivated again. Today I ordered rocker panels and fender patches. I just found a YouTube video on how to cut the windshield. Gotta try it. It's been a while since I could work on it since the holidays and buying a new house. But I drove the chop top to the house for its first drive and I want it done!!!
02-06-2015, 08:22 PM | #50 |
FYI you do not need to light alcohol, just let it eat laminate. Did not watch video.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
Tags |
1960, 1961, 1962, 1963, 1964 |
