Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 04-30-2014, 12:10 PM   #1
crhyno
crhyno's Avatar
WTB: Borg Warner T85N
Looking to purchase a Borg Warner T85N 3 speed with OD transmission. Want to keep my 62 C10 a 3 speed and this seems to be the way to get a little more highway capability that will bolt right up to my stock 235. Any leads will be appreciated.
crhyno is offline   Reply With Quote
Old 04-30-2014, 04:02 PM   #2
bonehead
bonehead's Avatar
Re: WTB: Borg Warner T85N
There are a bunch of them on ebay now. Take a look. good luck.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-30-2014, 04:10 PM   #3
crhyno
crhyno's Avatar
Hi
I am looking on ebay but cannot find this model. I see a few others (mostly Ford stuff) but maybe I am not using the right search. What are you searching on to find the T85N?
Old 04-30-2014, 07:16 PM   #4
bonehead
bonehead's Avatar
Sorry I was looking for Saginaw 3 speeds. Never heard of the Borg Warner model T85N.
past trucks:
Old 05-01-2014, 01:54 AM   #5
qksilver
Not sure, memory sucks but I have only seen Saginaw trans in chevy . I have two both of them bought off the board.
One used that i was told work well...........$250
The other completely rebuilt....................$650
can post pictures tomorrow, one is at the house the other at the shop.
Both over drive the rebuilt one has some of the wiring and stuff with it but not the pull handle and cable the not rebuilt is just the trans/overdrive. If I remember correctly they both have the solenoid.
The rest of the stuff is easy to find online and so is the manual. i have had a few installed in my vehicles both V-8 and sixes. After cleaning, rebuilding bearings if needed and proper adjustment of the steering column they did very well.
I would leave them in second to start off from a stop, when it hits around 17mph and they would go into overdrive then shift it to third then again it would go into overdrive. Only one shift after moving and both the 6 and the 8 would pull that without problems if he truck was not fully loaded or towing.
Let me know if you are interested otherwise I won't bother getting them out and taking pictures.
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 05-01-2014, 04:59 PM   #6
crhyno
crhyno's Avatar
Hi Steve
The BW transmission was a recommendation by some members here and the folks at stovebolt. I may have a line on a rebuilt one here on Long Island, but am waiting on an email reply. If I don't get that then I will be interested in your rebuilt unit. Thanks
Old 05-01-2014, 08:36 PM   #7
wahl4m
did this borg warner come factory in our trucks ? or what ?
wahl4m is offline   Reply With Quote
Old 05-01-2014, 08:52 PM   #8
crhyno
crhyno's Avatar
No, It would not have come standard in a Chevy truck. The following is from a Hemmings Motor News article:
Few transmissions can claim to be as popular with American manufacturers as the Warner T-85. From the mid-Fifties to the early-Sixties, you were likely to see it mounted behind the engines of most U.S. car makers. The helical-cut gears offered in the T-85 made it a much quieter transmission than its predecessors, which lent to its popularity as standard equipment in many three-speed applications during that time period. Some manufacturers such as American Motors and Ford added an electric overdrive, also designed by Warner, to the tail housing to make this transmission more reliable at highway speeds and more fuel-efficient. The T-85 was also the transmission that Warner tinkered with to build its most popular four-speed transmission, the T-10. The T-85 is popular with many classic car enthusiasts because it can be installed behind just about any engine size and can handle the higher torque and horsepower engines with ease. Although not used in any Chevrolets as original equipment, the T-85 will replace the weaker Saginaw three-speed with minimal installation problems.
Old 05-05-2014, 02:56 PM   #9
qksilver
there were also 2 different sag 3 speeds, again for what I remember, I have the style that is used in stock car racing, with out the over drive, stronger one.
Let me know here is my email I tend to forget
SCJKOVACH@AOL.COM
Steve
Old 05-07-2014, 10:09 PM   #10
DakotaKid
t85s came behind alot of FE powerd ford stuff from 58-68? it was the 3spd/OD in everything then for Ford.
Current Project : 1962 Chevy SWB Fleetside
Others, 1958 Edsel Villager Station Wagon
1926 Ford Model T Roadster Hotrod
www.suedescarclub.com
DakotaKid is offline   Reply With Quote
