Old 05-03-2014, 04:29 PM   #1
Houston Ben
Houston Ben's Avatar
Better sound deadener for cab: Spray in bed liner or Peel and seal?
Was thinking about doing so cheap sound deadener in the cab and wanted to know what everyone thought between the spray in bead liner or the peel and seal you can get at Lowe's?
Houston Ben is offline   Reply With Quote
Old 05-03-2014, 04:37 PM   #2
bigd65
bigd65's Avatar
Re: Better sound deadener for cab: Spray in bed liner or Peel and seal?
Peel and seal from Lowe's impressed me. I did mine and didn't even put padding back in for the carpet. Drove it around town and was quiet as a new truck... Well almost.... But i recommend everyone use the Peel and Seal...... They have a cheaper brand, probably did the same thing, but the PEEL AND SEAL even says for use on trucks
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 05-03-2014, 04:40 PM   #3
69chevytrucker
69chevytrucker's Avatar
I'm still putting my truck together but the first thing I did after all the floor patching and welding was spray top and bottom of my floor with bed liner and spray up the back on the inside almost to the back window
69chevytrucker is offline   Reply With Quote
Old 05-03-2014, 05:19 PM   #4
MalibuSSwagon
I plan on using the peel and seal as well, and topping it with fresh jute padding from the hardware store as well. My jute was wet and nasty from years of leaky old weatherstrips.
MalibuSSwagon is offline   Reply With Quote
Old 05-03-2014, 05:35 PM   #5
1981Stepside
1981Stepside's Avatar
If you lay down peel and seal, then lay down a layer of water heater wrap (looks kind of like aluminum bubble wrap) you won't have to put jute back in and worry about it getting wet and mouldy.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 05-03-2014, 06:26 PM   #6
king-918
king-918's Avatar
Originally Posted by bigd65 View Post
peel and seal from lowe's impressed me. I did mine and didn't even put padding back in for the carpet. Drove it around town and was quiet as a new truck... Well almost.... But i recommend everyone use the peel and seal...... They have a cheaper brand, probably did the same thing, but the peel and seal even says for use on trucks
x2
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-03-2014, 06:33 PM   #7
69chevytrucker
Name:  truck paint 126.jpg
Old 05-03-2014, 09:53 PM   #8
andrewmp6
What about lizard skin its a spray on sound deadening. http://www.lizardskin.com/
Old 05-03-2014, 10:44 PM   #9
silverbear
silverbear's Avatar
I used Al's liner HNR (Heat and Noise Reducer). It was recommended to me by a friend and it works really good. A gallon is about $45 on Amazon. What you see in the pictures (tan color) of my cab is two coats than I rolled on with a 3" roller. I used about 15% of the gallon to lay down the two coats.
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
Old 05-03-2014, 11:36 PM   #10
t_graham11
I used quick roof that I bought from Rona. But before I put it down I plasti-dipped the areas I was going to lay it. I did a test to make sure it would come up easily and it came up without a problem, figured I would do it that way incase I wanted to tear up the quick roof.
t_graham11 is offline   Reply With Quote
