Old 05-08-2014, 01:53 AM   #1
terbronco7
terbronco7's Avatar
Tranny swap
Currently I have a 230 with a granny 4 speed, My question is this will a power glide bolt right up to my 230 or is there something else that needed?
terbronco7 is offline   Reply With Quote
Old 05-08-2014, 06:47 AM   #2
PGSigns
PGSigns's Avatar
Re: Tranny swap
It will bolt up to the 230 but not sure if you want to go that route. A powerglide will have a 1.76 or a 1.82 first gear. So starting off will be close to 3rd gear in the trans you have. A turbo 350 would be a better choice.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-08-2014, 09:34 AM   #3
terbronco7
terbronco7's Avatar
Re: Tranny swap
Yeah I was thinking the same, 350 would bolt up as well?
Old 05-08-2014, 12:13 PM   #4
PGSigns
PGSigns's Avatar
Re: Tranny swap
They will all bolt up as long as it is a chevy trans. You will need to find one the right length and put a trans cross member in it. Cut out the old cross member behind the engine and figure out a shifter and a cooler.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 05-08-2014, 05:01 PM   #5
morethanstock66
morethanstock66's Avatar
Re: Tranny swap
If you are looking for strength and reliability, a th350 or th400 all day every day over a powerglide. If you want nostalgia, powerglide. They should bolt up no problem, if not gm, then all you need is a new bellhousing and those are relatively inexpensive.
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 05-08-2014, 05:27 PM   #6
terbronco7
terbronco7's Avatar
Re: Tranny swap
Thanks I like the idea of original period look but for overall ride I think I will go with the 350 or 400.
Thanks everyone
