Old 05-08-2014, 04:45 PM   #26
BlacklandCamper
Re: How can I level?
I would like to see how they look fitted.
I'm looking at the specs for the Moog 6560 now, they show an 11in install height, a 13.19in free height, with a 3289lb load, but the spring rate is 1501in/lb. The 6560S has a rate of 1464in/lbs.
The Moog 6454 is a 13.61in free height, with a load rating of 3841lbs, and a spring rate of 1060in/lbs, but the install height is only 10in. These are a match to the Napa part number 2772074.
I would swap the 6560S for the 6454, you'll have some money coming back if you do.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 05-08-2014, 05:02 PM   #27
Aruba1
Yeah, I did some search online and indeed the napa 2772074 springs are the same as the moog 6450. I just bought a set at autozone that had one in stock and I hope to get them installed tonight. If the 6450 work, I will post some pics of the different setups. Hope nobody else makes my mistake and try to in stall the 6450S, I reckon they won't be able too unless they have a backhoe or something to put a few thousand lbs on the front to be able to compress the a-arms.
Aruba1 is offline   Reply With Quote
Old 05-08-2014, 05:57 PM   #28
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Good luck I hope it works. Keep us posted and provide some pictures.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-08-2014, 10:03 PM   #29
Aruba1
Moog 6454 or NAPA 2772074 is the winner. The truck drives great, very stable and firm. I love it. I have two tires sizes on the front, on one side I have BFG KO 235/85/16 and 36-1/4" of fender clearance. The other size I have Goodyear 245/75/16 and almost 35" clearance. I have another goodyear tire that I was planning on having it mounted this weekend but plans have changed, I want that extra clearance so I will be on the lookout for another KO. I hope to post some pictures this weekend. Thank you all, Gio
Oh, best of all, I didn't have to use the backhoe this time, LOL.
Old 05-08-2014, 10:31 PM   #30
derotoreut
derotoreut's Avatar
Congrats. Glad to hear that it worked out. I can't wait to see pictures. Please post pictures or tell us the measurements from ground to fender. I did a similar thing when I installed a lift kit on my '70 K10. I took measurements from ground to curved point of fender and also top of tire to same point.
~ Dan
Old 12-04-2015, 09:40 AM   #31
1968aj
Originally Posted by aruba1 View Post
moog 6454 or napa 2772074 is the winner. The truck drives great, very stable and firm. I love it. I have two tires sizes on the front, on one side i have bfg ko 235/85/16 and 36-1/4" of fender clearance. The other size i have goodyear 245/75/16 and almost 35" clearance. I have another goodyear tire that i was planning on having it mounted this weekend but plans have changed, i want that extra clearance so i will be on the lookout for another ko. I hope to post some pictures this weekend. Thank you all, gio
oh, best of all, i didn't have to use the backhoe this time, lol.
i know this is a old thread. Does anbody know if these springs will raise the front of my 1972 c/20 longhorn?
1968aj is offline   Reply With Quote
Old 12-04-2015, 01:32 PM   #32
BlacklandCamper
Those should do the trick. I plan on using them on my C20 Custom Camper.
Old 12-10-2015, 03:11 PM   #33
b.sharp
b.sharp's Avatar
ok, in reading through this I was wandering if all these trucks were running big blocks which would offset the weight quite a bit from my small block c20 application. Could I use the same springs to level my c20/350/4 speed truck?
b.sharp is offline   Reply With Quote
Old 03-16-2016, 09:26 AM   #34
Ringo934
Ringo934's Avatar
Did you ever do thiss Mod? I too have a small block and want to do it?
1969 GMC C/1500 LWB Wideside
355 SBC/TH400/3.73 posi-traction
Daily Driver.
Carburetors, because I don't care to consort with that of the robot race.
Ringo934 is offline   Reply With Quote
Old 04-19-2016, 03:49 PM   #35
benbloom
Did you have to make any other changes to the suspension or alignment when you did this? or can you just pop the bigger springs in there, with the same shocks and ball joints and all?
benbloom is offline   Reply With Quote
Old 04-19-2016, 09:57 PM   #36
ItWillBeSlow
ItWillBeSlow's Avatar
You'll probably need an alignment. I used the springs Dan posted and used the same shocks and ball joint. I love the look, it is noticeably stiffer
1972 C20
ItWillBeSlow is offline   Reply With Quote
Old 04-20-2016, 06:55 AM   #37
Ken B
Wow this is something I have really wanted to do and all of a sudden I see a new thread on the topic! I think my C30 LongHorn will look pretty good leveled out? What do you guys think?
Ken B is offline   Reply With Quote
Old 11-19-2017, 02:21 AM   #38
KevC20
I wanted to check if these springs (NP 2772074 or MG 6454) are still recommended to do this front end lift. Its been a while since the posts and wanted to see if there are any new recommendations.
I was going to order the sprigs this week. Thanks
71/C20 350
KevC20 is offline   Reply With Quote
Old 03-10-2018, 11:31 AM   #39
packman33
Junior Member
I just ordered the NP2772074 springs to level the front of my '70 C20. I will keep this thread posted on results. I did however, have a question about what springs y'all are running on your C20's that you've liked the best. Please advise and thank you in advance.
packman33 is offline   Reply With Quote
Old 11-01-2018, 10:37 PM   #40
Whitetaildeer
Can you tell me what shocks you used with those front springs?
Whitetaildeer is offline   Reply With Quote
