Old 05-09-2014, 12:03 AM   #1
63burb
63burb's Avatar
94 in to a 63
So my DD a 94 silverado ext cab finally gave out. I got hit on the passenger side and a few weeks later the transmission gave out but with every sad story there a happy story.. I want to swap whatever I can in to my 63 suburban starting with the front suspension, any ideas on that? Should or can I do a full crossmember swap like with the 67-80 crossmembers? Can I use the brake buster? Any input helps.
63burb is offline   Reply With Quote
Old 05-09-2014, 12:21 AM   #2
Captainfab
60-66 Nut
Re: 94 in to a 63
You can not use the front suspension on your '63. The '88 and up suspensions and steering are completely different. Yes you can use the brake booster. It will be a direct bolt up with one of my booster brackets. You could use the engine with either the TBI or change it over to a carb. The seats should work, but depending on the style of the seat(s), they may limit access to the back seat in your Burb.
Old 05-09-2014, 12:35 AM   #3
63burb
63burb's Avatar
Re: 94 in to a 63
That's definitely not what I wanted to hear =/ I guess I have to come up with a different plan then.. Thanks for the input captainfab
