Old 05-09-2014, 03:37 PM   #1
bowcoffin
Propane Conversion
Hey guys,
Anyone have any knowledge about pros or cons of converting to propane? What all would I have to do to my "Inners"? Would you recommend it? Seems like the more efficient way to buy fuel...
Thanks!
bowcoffin is offline   Reply With Quote
Old 05-09-2014, 04:09 PM   #2
Moline_Puller
Moline_Puller's Avatar
Re: Propane Conversion
There are a lot of good things about running propane...your engine will love it...very little carbon in the fuel (less need for oil changes), 105-110 octane, easy cold starting (well, down to -40 degrees, at least). The only bad thing is having a good source of propane...well, your fuel efficiency will drop about 10% too!
I've thought a lot about switching to propane...I used to compete with a pulling tractor that ran on propane and I loved it! And I'm still planning on switching my truck over at some time!
Here is a link that will answer further questions...
http://www.gotpropane.com/p4.html
Good luck!
Moline_Puller is offline   Reply With Quote
Old 05-09-2014, 04:29 PM   #3
imjeff
imjeff's Avatar
Shorter range, less power. You don't need to change internals, but you can get better performance by purpose building a propane motor (it's still less btu/gallon) if you want to run only propane.
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 05-09-2014, 10:01 PM   #4
68gmcdually
68gmcdually's Avatar
We have a '93 Silverado 1500 with a 350 and a '96 3500HD with a 454 both on propane since new at work. We've had great success with them. My '68 motor was on propane and I wish I had of kept it that way.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 05-10-2014, 08:13 AM   #5
Mike C
Mike C's Avatar
Propane is only down slightly on BTU compared to gasoline. I have a '61 John Deere 4010 on LP and love propane as a motor fuel. The gasoline tractor and propane tractor had almost identical power outputs, the concession was the LP motor had a full point higher compression to make up the difference.
The 4010 has a 60 gallon tank and I use a 250 gallon with a siphon installed to refuel. Like an air tank, you can only get a full refill the first 3 times or so then need the gas company to refill. But on the road you won't have to worry about that.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 05-10-2014, 11:01 AM   #6
imjeff
imjeff's Avatar
The actual btu numbers per gallon are 125,000 for gasoline and 90,000 for propane. We had a dual fuel truck in 1976. I'm sure the systems are way better today, but where do you fill up? When I had my camper we had a heck of a time finding propane stations that were open. Lots of "that guy is off today", etc. Not a huge deal for cooking gas, but it could be a giant pain on the road.
72 K10 396
75 Cj5 MPI 350 Chev
74 FXE
08 Tahoe
