05-10-2014, 07:18 PM | #1 |
Need direction
I need ideas and motivation!
I've had my project for a few months and its running like a champ but now I can't figure out what to do with it. I've thought about every single color and combination but can't settle on anything. I'm looking for value and appreciation of the project. 1. I don't really want a rat rod, i know its the perfect start. 2. I want something i can resell if needed so not an absurd investment but does have some value. 3. I'm not going to bag or lower it. I'd like suggestions on color combinations, I'm leaning towards pin stripes on the sides and down the hood, two tone bright red bottom and either white or silver top. I'm in Texas so black is too hot and my mustang is already blue. Is it a pain to get the cab off the frame? Can i just unplug the wiring/steering/brakes unbolt and lift it off? Is it worth the effort to clean up the frame? Transmission tunnel cover was in the bed, the passenger side isn't as bad but still rusty. |
05-10-2014, 07:22 PM | #2 |
Re: Need direction
Looks pretty cool as-is. Put some clean tires on it and shiny trim and call it a day.
Rockin' a '66 and loving every minute of it |
05-10-2014, 07:40 PM | #3 |
Re: Need direction
you could try plasti dip its cheap and if you dont like the color you could peel it off, did my tailgate to try it out neat stuff not completely sold on it though
05-10-2014, 08:25 PM | #4 |
Re: Need direction
What is the original color? I would paint it that mint color with white accents. I know there is a GM paint name but I don't remember it right now. Here is a Hot rod flatz color that is similar. I used the speed blue and now wish I went with this color. It's easy to use and the satin color looks nice. Come by and see it if you want I live in Killeen.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
05-10-2014, 08:31 PM | #5 |
Re: Need direction
Other than wires and lines it's about 6 bolts to get the cab off. Then you'll need a cherry picker or 4-5 strong friends to lift it off .
05-10-2014, 08:36 PM | #6 |
Re: Need direction
I would try and find a GMC hood for it
05-10-2014, 09:09 PM | #7 |
Re: Need direction
Some matching shoes would help a bit.
05-10-2014, 11:29 PM | #8 |
Re: Need direction
wow...Cool
I would drive it ya change the shoes but drive it if its a work truck leave as is... if its your Pleasure... Bagg it & sway bars as far as paint google "C-10 images" see something you like and have an open checkbook Go for it Please post pictures of truck in progress....Sp . if it was me and i had old family Oil money I would do a tribute to this . . .
My Spelling is Not Incorrect...It's 'Creative' . . 1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E http://67-72chevytrucks.com/vboard/s...d.php?t=789617 59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341 |
05-10-2014, 11:42 PM | #9 |
Re: Need direction
I may try plasti dip so I don't have to sand off a bad decision. I bought small amounts of 4 different blues before picking the color for the mustang, I knew exactly what I wanted just couldn't seem to find it. I just don't know with the truck.
It has matching wheels, I only had to swap 3 to get it onto the trailer and removed as much tread from the last one as I could before it gave out. I plan to change them to something chrome with raised white letters, just got those to roll around on. The mint color is one of them I'm tossing around or one of the blues that is already on the truck but i figured with a big block red might be more hot rod'ish. |
05-10-2014, 11:51 PM | #10 |
Re: Need direction
That truck is amazing and I love the tailgate and styling they used, very classy! No oil money but I have all the tools and some materials left over from the first toy so it will be sheet metal and paint, I'm only in it for maybe 1200 at this point. Where is everyone getting their metal from? LMC? I need new front fenders, too much to try and hammer out dents plus patch rust.
05-11-2014, 12:02 AM | #11 |
Re: Need direction
05-11-2014, 09:22 AM | #12 |
Re: Need direction
05-11-2014, 10:56 AM | #13 |
Re: Need direction
my suggestion is you can never go wrong with original.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
05-11-2014, 11:05 AM | #14 |
Re: Need direction
Depending on how you value your time and/or pay others, it may be a challenge to get your investment back out of it...let alone make money on it.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
05-11-2014, 12:01 PM | #15 |
Re: Need direction
I would do mechanical and issues first then worry about paint. Some rims with caps to keep a stock feel. I have a buddy who has a truck in the garage with over 10 years on the paint but has not been on the road. Me, truck has been primer since day one but on the road most of the time. Perfer to drive while working on it.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
05-11-2014, 09:07 PM | #16 |
Re: Need direction
05-12-2014, 08:45 AM | #17 |
Re: Need direction
The gmc and chevy hoods are interchangeable, but have different park/turn lamp lenses
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
