05-11-2014, 01:55 AM | #1 |
Blower Motor Replacement
The blower motor in my '72 Burb lost high speed so I figured I would replace it. Should have looked at the forum first because it appears that the high speed relay is actually the problem. Now I have a new motor and the old one almost out, and now it has become a challenge. Am I missing something, or do you have to remove the hood hinge to get the motor out/in. I replaced the blower in my grand prix in about 15 minutes. The one in my Burb is killing me. Any help would be greatly appreciated.
Thanks, Ryan |
05-11-2014, 07:38 AM | #2 |
Re: Blower Motor Replacement
If I remember right you need to remove the hood hinge .
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
05-11-2014, 08:25 AM | #3 |
The Older Generation
You don't have to remove the whole hinge, just the bolts on the inner fender. Be sure and put a folded heavy towel or other soft padding between the hood and cowl panel/fender. Also mark around the hinge with a fine felt tip marker before you remove the bolts so you can get it back in the exact same place before you tighten the bolts back up.... You can block the hood up with a piece of wood or something similar while you do this, but I would have a helper hold the hood in place while you tighten the bolts up. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-11-2014 at 08:30 AM. |
05-12-2014, 12:14 PM | #4 |
I thought that was the case. Thank you very much for the input.
05-14-2014, 01:23 AM | #5 |
BlahBlahBlah
I was thinking what kind of blower motor has high speed? Only one I could think of was the blower on Mad Max's car. Yes, I finally figured I out =)
