question on rear shocks, after flip kit
I have a 85 GMC short bed. So far I have purchased a lot of parts to get the look that I am after. So here is the list: 3 inch Bell tech spindles, rear flip kit, and I have a set of Cal-trac traction bars on order. My plan is to cut one coil on the front springs, install the drop spindles, and flip the rear. So far it all sounds like I am OK. But what I am a little lost on is the rear shocks. I thought I read on this forum at one time, that after the flip you could run the front shocks on the rear. I guess what I am asking is what options, other than drop shocks, is everyone using?
Re: question on rear shocks, after flip kit
I have used shock extenders in the rear, and that probably would be my favorite way.
It also gives you a better shock angle. |
I made my own flip kit and extenders. They worked awesome.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
I used Gabriel air shocks on mine...works like a charm
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
X2 on the shock extenders.
#6 | |
Can u give me a parts number on the Cal-trac traction bars u are going to use.. I'm thinking of getting some.. I hope they can help with the axle wrap problem that I am having..
Will I ever finish my 1986 stepper.. |
yea, I'd be happy to. As soon as they come in. Hopefully by this Friday.
I used shock extenders and rear OE replacement shocks
Shock extenders: http://www.summitracing.com/parts/ws...et?prefilter=1 Rear Shocks: http://www.rockauto.com/catalog/more...543&cc=1059825
1977 SWB C10 - "Woodson": 5.3 Vortec LS Swap, 4L60e Trans, 4.5/5 drop Last edited by BigMike608; 05-14-2014 at 08:24 AM. |
yeller
I always run dropped shocks. I like the Bell Tech Nitro Drops. Not a fan of shock extenders...seems like more parts that really aren't needed. KISS.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
I'm running shock extenders and stock replacement shocks with a 4.5/6 drop. I'm pretty sure the cost was the same if I used drop shocks or shock extenders and stock replacement shocks. The ride is fine on the rear with this set up, but I need drop shocks up front. The stock replacement shocks up front are a little too bouncy.
Azulita - 84 Chevy Scottsdale Longbed 305/350 |
are drop shocks, or extenders mandatory? i put stock shocks on mine after the flip kit, but i haven't driven it yet... do i need to worry?
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
Just wanted to say thanks, to all for the suggestions.
I have been collecting parts for several months now. I just need to get after it. The plan is to get the motor in, and break in the new camshaft. Then all of the suspension pieces go into place. Hopefully I'll have more to report in a few weeks. |
I haven't figured out how to post multiple pictures yet. Wanted to post a picture of the Truck as well. I plan on getting the motor and suspension worked out, then I will work on body and paint.
#15 |
I received some goodies today. I am so excited. The part numbers that I ordered was TBK6798. I hope in the next few weeks I can be installing, and will try to post some pictures then.
#16 |
Thanks.. For the parts # on the trac bars.. You have a really nice truck..
#17 |
Have you found the answer to this? Just flipped mine - have some old air shocks but want to go with regular shocks. Drop shocks (or extender brackets) are absolutely needed?
#18 |
Diggin The SquareLife
Yes. Drop shocks and extenders are needed shocks to for change of the height an extenders to correct the angle an take stress of the shock mount
#19 |
I didn’t want to start a new thread but I also have the same question regarding drop shocks and shock extenders. I purchased my western chassis flip kit and getting ready for a 4/6 drop on my 1980 c10. I see belltech offers the street performance shocks with different drop ratings but I see people say they still use shock extenders for the rear and front. Others say they use it only for OEM shocks and hear that KYB shocks are the best.. If that’s the case, I’ll be ordering the front and rear shocks extenders from western chassis but I like to hear what others are doing. I want the best shock ride and get a way from the c notch. Thanks!
#20 | |
Drop shocks can work if the valving is correct for the application. Stock length shocks offer more travel which usually yields a better ride quality (the longer the shock & spring, the better the ride usually is). Relocation brackets are typically used to keep the shock geometry in check as well as restore some travel length when using a stock replacement shock.
