Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 05-13-2014, 08:32 AM   #51
SparkyRnD
SparkyRnD's Avatar
Re: RnD Fabrication 1967-1972 Chevrolet & GMC early C10 / C20 / Blazer Radiators!
back up top, remember to mention that you are a forum member to get your discount!
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline
Old 05-22-2014, 09:16 AM   #52
SparkyRnD
SparkyRnD's Avatar
please keep us in mind if you need a radiator for your project, we would love the chance to help cool your truck
Old 06-13-2014, 08:26 AM   #53
SparkyRnD
SparkyRnD's Avatar
thanks for the continued support!
Old 06-25-2014, 03:34 PM   #54
SparkyRnD
SparkyRnD's Avatar
up top
Old 07-01-2014, 09:48 AM   #55
SparkyRnD
SparkyRnD's Avatar
We will be closed on Friday in observance of the 4th of July. Thanks again for the support!
Old 07-20-2014, 01:36 PM   #56
Lee H
Lee H's Avatar
Will be calling you to discuss a radiator for my 72 C10. Now that all the local autohouse replacement radiators, at least in my neck of the woods, have plastic tanks I will be going custom after market. I know the plastic tanked rads will work fine but just can't get my head around seeing that in my old truck.
Assuming your radiators utilize the stock 4 core mounts and cushions, have the trans cooling line fittings on the right hand side, have the heater core return fitting in the right hand end and can be plugged if not used. I'll ask these questions when I call to order.
Lee
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline
Old 07-21-2014, 05:34 PM   #57
SparkyRnD
SparkyRnD's Avatar
We look forward to it. We build ours to fit the 4 core mounts, but use the 3-core cushions (that way they'll fit both the 3 and 4 core setup's). We can put the trans cooler on the passenger side (we only put it on the driver side for LS conversions). For the heater core fitting, we can add that (most people don't request it, but its easy to add).
Old 07-24-2014, 06:10 PM   #58
SparkyRnD
SparkyRnD's Avatar
back up again
Old 07-29-2014, 01:20 PM   #59
k2rm
k2rm's Avatar
Can you provide more info on the dual fans? Size, CFM rating, and current draw? How noisy are they when running?
k2rm is offline
Old 07-29-2014, 04:26 PM   #60
SparkyRnD
SparkyRnD's Avatar
Sure. Our dual 12's pull a combined approx 2,900cfm, are 12v and draw around 11amps. They are not very noisy at all.
Old 08-05-2014, 10:33 AM   #61
SparkyRnD
SparkyRnD's Avatar
Back up again, remember to ask for your discount when ordering (or tell us you found us here)
Old 08-05-2014, 12:15 PM   #62
Lee H
Lee H's Avatar
I'm having a difficult time finding three row cushions that fit in the four row mounts. Either out of stock with no idea of when they are coming in or no clue of what I'm asking for. If you have a source please list it. Maybe you could offer and accessory package for a nominal fee that contains the cushions, petcock, overflow hose, etc.
Lee H is offline
Old 08-05-2014, 01:04 PM   #63
SparkyRnD
SparkyRnD's Avatar
The cushions most people told me they used were sourced from summit or from other vendors here. We will look into the accessory package, as that may be a viable solution.
Old 08-05-2014, 11:50 PM   #64
67ctener
67ctener's Avatar
Not to take this the wrong way or question your work cause it looks outstanding, and american made, but is anyone running one of these yet? Just looking for any feedback. I'm running a mild 402 in my 67 and will soon be in need of a cooling system. Don't like the price tag on be cool and skeptical on champion radiator this seems like a good alternative. I am wanting to run electric fans but not wanting real loud and something reliable with long life. Nice product and glad to see you as board vendor
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline
Old 08-06-2014, 08:58 AM   #65
SparkyRnD
SparkyRnD's Avatar
No offense taken, there are at least 30-40 guys on here that have bought our radiators.
Old 08-12-2014, 01:21 PM   #66
SparkyRnD
SparkyRnD's Avatar
back up again
Old 08-13-2014, 04:50 PM   #67
CST10
CST10's Avatar
Sparky, I have a 454 BBC bored .040 over. Mild cam, etc. puts out 500 ft lbs 475 hp. Currently running dual electric flex lite fans pulling 4300 cfm at 12 amps.
Temperature runs 210* consistently with the hot weather.
With just a radiator swap from a new 4 core to yours, what if any temp drop might I expect?
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 08-18-2014, 03:49 PM   #68
SparkyRnD
SparkyRnD's Avatar
I would think you should see at least a 10-15 degree difference assuming the fans really pull what they are rated for.
Old 09-05-2014, 12:01 PM   #69
SparkyRnD
SparkyRnD's Avatar
Contact us to keep your truck cool!
Old 09-19-2014, 12:05 PM   #70
Lee H
Lee H's Avatar
Received my radiator, impressed with the quality and workmanship. I'll report back when I install it this fall. Do you recommend and additive along with prestone and distilled water like redline, lucas, or.....?
Lee H is offline
Old 09-22-2014, 08:52 AM   #71
SparkyRnD
SparkyRnD's Avatar
While you can run those additives, it isn't necessary in most cases. Just a good antifreeze mixed with distilled water is what we recommend.
Old 10-07-2014, 08:49 AM   #72
SparkyRnD
SparkyRnD's Avatar
back up again
Old 11-03-2014, 09:08 AM   #73
SparkyRnD
SparkyRnD's Avatar
thanks again for the support guys, and let us know if we can help on your project!
Old 11-13-2014, 12:43 PM   #74
SparkyRnD
SparkyRnD's Avatar
back up top
Old 11-19-2014, 10:40 AM   #75
SparkyRnD
SparkyRnD's Avatar
Remember to ask for your discount when ordering!
Closed Thread
