Old 05-13-2014, 08:20 PM   #1
JacobSchni
JacobSchni's Avatar
How do I lower my steering column?
I found that my truck was not starting because the ignition switch need adjusting so the rod become more tight. I have the 2 bolt mounting the steering column to the dash out. what else do I need to do to lower it to about the seat, so i can adjust. Please tell me anything, a video would be great if there is one out there.
JacobSchni is offline   Reply With Quote
Old 05-13-2014, 09:38 PM   #2
willett
Another Day, Another Dollar
willett's Avatar
Re: How do I lower my steering column?
Should drop quite a bit with those 2 bolts you undid. If my memory serves me right you should be able to pry the strap the bolts were holding on off of the mounting studs it will come down enough.
Other than that there are some more bolts that hold the firewall plate to the firewall and the pinch bolt for the yoke that you shouldn't have to mess with.
This is all from Memory and its been a while since I had my column out... Lol
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
Old 05-13-2014, 10:30 PM   #3
JacobSchni
JacobSchni's Avatar
what do you mean by pry the strap. if im thinking right are you talking about that plate that the bolts were tightened onto. and how much pressure would it take because it seems like its still in there really firm and i dont want to break anything.
Old 05-14-2014, 01:02 PM   #4
willett
willett's Avatar
It's probably caught up on the threads.
Old 05-14-2014, 03:29 PM   #5
JacobSchni
JacobSchni's Avatar
Do u know where a picture of the bolts are. I think I might have taken out the wrong bolts
Old 05-14-2014, 04:44 PM   #6
willett
willett's Avatar
See the 2 bolt channels 3/4 of the way up the column? There's a tutorial on doing it underneath.
http://www.73-87.com/7387garage/inte...stallation.htm
