Old 12-22-2003, 04:31 PM   #1
Davy
Davy's Avatar
Blazer Body mount kits
Who has the best kit? Anyone have any opinions? I want to go with rubber, not poly.
I want to get my rockers redone, but I think I better get the body on straight before I do that.
Thanks for any advise,
Davy
1970 Blazer CST
Looking for NOS items for my CST restoration.
Davy is offline   Reply With Quote
Old 12-22-2003, 06:22 PM   #2
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I just got my set from Kenny's and they are supposed to be like original, but seem a little more plastic. It does not come with bolts either by the way. $95 plus shipping. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 12-23-2003, 02:52 AM   #3
DaHateTank
Thumbs up
I got the kit from LMC. Was a bit more $$$, but came with the bolts, if I remember right.
Made a big difference in how my heap rode!!!
-M
DaHateTank is offline   Reply With Quote
Old 12-23-2003, 04:10 PM   #4
Bluegoose972
Ok...Maybe a stupid question...But why would you NOT want Poly mounts? I've never heard anything but good things about them until now....so I'm curious.
Bluegoose972 is offline   Reply With Quote
Old 12-23-2003, 05:07 PM   #5
Davy
Davy's Avatar
Bluegoose,
Good question. Maybe poly is better...anybody know? I was told that they made the already rough-riding Blazers even more rough-riding. I suppose poly would last longer?
Any opinions??
Davy
1970 Blazer CST
Old 12-23-2003, 05:27 PM   #6
meathead95
computer illiterate
meathead95's Avatar
i have heard if your floor pans or supports are weak the poly mounts have no flex and can push through
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 12-25-2003, 11:15 AM   #7
pound41
The polys have more durability because they are stiffer and that stiffness transfers over in the ride. Ride is not as smooth as rubber since it doesn't give. Just a matter of choice. Good rubbers are More $$ than polys
pound41 is offline   Reply With Quote
Old 12-28-2003, 10:51 PM   #8
DaHateTank
urethane mounts squeak. My friend's truck is pretty damn annoying.
Plus, all the urethane bushings Ive had, seem to get crumbly, after a few years, which is a direct contradiction, to the claims that they last longer than rubber...
-Marty
Old 12-29-2003, 09:02 PM   #9
K5 Blazer
Blazerologist
K5 Blazer's Avatar
Rubber is definitely better. Rubber gives poly doesn't. Poly should be only used for sway bar issues. www.vintageblazer.com Complete kit with all hardware and core support 140.00
www.californiak5.com
K5 Blazer is offline   Reply With Quote
Old 12-30-2003, 10:30 PM   #10
rogf4
To each his own if you buy good poly mounts you will have good luck (Energy Suspension)is all I have ever used. A friend of mine has a new set of Energy Suspension Poly cab Mounts for 67-72 blazer for sale
rogf4 is offline   Reply With Quote
Old 01-01-2004, 01:01 PM   #11
69k5
how much?
69k5 is offline   Reply With Quote
Old 01-01-2004, 05:15 PM   #12
skid
I read somewhere that polyurethane is similar to rubber in that the durometer (basically hardness) isn't fixed, and can be made to whatever hardness the manufacturer wants to make. I don't have any experience with poly body mounts, but would be interested in other's opinions of the different types available for our trucks. Anybody have them??
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 01-01-2004, 10:25 PM   #13
rogf4
Hey 69k5 I will check with him for a price and get back with you
Old 01-04-2004, 02:37 AM   #14
rogf4
Hey 69k5 he has 2 sets one new in box $80.00 plus shipping one new installed and taken off blazer was wrecked right after install $50.00 plus shipping both are poly (energy suspension)
Old 01-05-2004, 04:30 AM   #15
GMCPaul
We keep in stock both of the complete Blazer rubber Radiator & Body mounting kits with all hardware for both 2 wheel & 4 wheel drive Blazers. Be sure to specify in the comments section 2 wheel or 4 wheel drive, and year of Blazer as all years are not the same style bushings.
You'll find them here
http://www.gmcpauls.com/rubber_&_weather_strip_21.htm
GMCPaul is offline   Reply With Quote
Old 01-05-2004, 11:20 AM   #16
Davy
Davy's Avatar
GMCPaul,
Can you tell us your experience with rubber vs. poly mounts? Any opinions?
Thanks,
Davy
1970 Blazer CST
Old 01-05-2004, 10:55 PM   #17
DaHateTank
Unhappy
My friend's noisy POS has energy Suspension mounts. Its a rust free cab, as well, so its not anything else makin' the noises.
The crumbly ones were factory erquipment from Rancho, and some el-cheapo ones I got a at a local 4X4 shop...
-Marty
Old 01-06-2004, 05:52 AM   #18
GMCPaul
The rubber ones reduce vibration felt from engine and drivetrain more than the poly do, the rubber ones will also not pull through a rusted frame bracket or body as soon as poly will due to the poly mounts that are made being stiffer but if its rusted bad enough even rubber mounts will pull through.
The poly though will reduce body roll helping or sway found in hard cornering, and poly will not break down from high salt conditions.
GMCPaul
