Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-14-2014, 10:07 AM   #426
jaros44sr
jaros44sr's Avatar
Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Thanks, yeah, that might work.right now im leaning towards a small mesh wire basket for the baffle in the v/c, any thoughts?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 05-14-2014, 10:52 AM   #427
Wasted Income
Boosted Member
Wasted Income's Avatar
i used a solid piece of aluminum to keep liquid oil from splashing into the breather fitting. It's open on the sides to allow air movement, but no direct oil ingestion.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-14-2014, 01:01 PM   #428
jaros44sr
jaros44sr's Avatar
OK, let me think about that, might be a better solution than what i had in mind. Further thought on the adapter/fitting you posted may very well work, just have to cut a hole that it will screw into, dont know yet what that hole will have to look like. Maybe just buy the fitting and go from there
Thanks for your time and help, this PCV has got me fustrated
SAFETY FIRST
AS usual, off topic
Jim
Old 05-14-2014, 03:00 PM   #429
Wasted Income
Boosted Member
That PCV is meant to take the place of the oil filler cap, lol.
If you wanted, you could probably run two passenger side valve covers with these fittings, and you'd have two -10 crankcase vent ports ready to go.
Turbo diesel
Old 05-14-2014, 03:04 PM   #430
Wasted Income
Boosted Member
Originally Posted by Wasted Income View Post
Here is something you might find helpful as well.
http://www.hawksthirdgenparts.com/pr...N-Fitting.html
Disregard. I had to go back and review your thread and remembered you aren't running an LS....so it is going to be mighty tough to run LS valve covers,
Turbo diesel
Old 05-14-2014, 06:14 PM   #431
jaros44sr
jaros44sr's Avatar
Dang, oh well, back to the drawing board, as they say....i so had my hopes up as far as that can being the answer
Thanks for trying
SAFETY FIRST
AS usual, off topic
Jim
Old 05-15-2014, 09:48 AM   #432
Wasted Income
Boosted Member
Thanks for trying
Here's what I would do. Not sure if your valve covers are aluminum or steel, but either way, I'd get the approprate -8, -10 or -12 fittings, and weld them on, then run to a catch can.
http://www.summitracing.com/parts/ae...FYtAMgodXWUAIw
http://www.summitracing.com/parts/sum-220062/overview/
Turbo diesel
Old 05-15-2014, 11:07 AM   #433
jaros44sr
jaros44sr's Avatar
Yeah, it looks like your right. Ill just have have to find a good place around my LS1 COIL packs, v/c is aluminum.
Saw the can at peterson fluid website while i was sourcing dry sump systems...
Thanks for your help
SAFETY FIRST
AS usual, off topic
Jim
Old 06-02-2014, 09:40 AM   #434
Wasted Income
Boosted Member
Got the top finally pulled off on Friday evening.
Bunch of local guys got together and had a dyno day on Saturday.
I didn't put up any hero numbers, but I'm happy with the result on a rough street tune with soft timing, and the lowest boost I could run (9 psi). Gonna get the boost controller plumbed up and start to sneak up on it. Should be fun, as this turbo really STARTS to come alive and becomes efficient around 18 psi. Will probably bump the rev limiter up a bit too, since it was still climbing pretty good when I shut it down around 6300.
Video:
Turbo diesel
Old 06-02-2014, 11:12 AM   #435
lopemaxx
lopemaxx's Avatar
nice work Jeff!! the giggle factor is pretty high
70 Chevelle SS (clone), 454, 350 auto
71 K5 350, 350 auto, 3" body lift, 35's
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |____|__|___]
*.*..*.*.._@_ _ _ _ @
lopemaxx is offline   Reply With Quote
Old 07-05-2014, 01:34 AM   #436
67-72trucks
Awesome work!! Very nice!!
67-72trucks is offline   Reply With Quote
Old 07-07-2014, 02:13 PM   #437
Jon01
Jon01's Avatar
Good #'s for low boost!
What are you running for a muffler? It sounds nice!
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 07-10-2014, 12:21 AM   #438
CheyenneShop
CheyenneShop's Avatar
This is one bad a$$ blazer - damn!!
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 07-15-2014, 08:59 AM   #439
Wasted Income
Boosted Member
Thanks guys
I built a 4" aluminum down pipe and used a Vibrant 4" aluminum muffler with it. It also has the wastegate dumped to atmosphere.
Turbo diesel
Old 07-27-2014, 08:55 PM   #440
low69chevy
low69chevy's Avatar
Post Re: Project Family Truckster: 2wd Conversion Turbo LSx Blazer Build
Read thewhole thread right now nice build I had seen videos of it before on YouTube and saw the build thread right now and had to read it hope to do a similar setup on my 69 c10 how you like that holley intake and that dominator I've seen a lot of the fast trucks back at home going to that holley dominator setup
low69chevy is offline   Reply With Quote
Old 07-28-2014, 08:55 AM   #441
Wasted Income
Boosted Member
Thanks man. The intake looks badass, no doubt. Can't really say if it hurt, helped, or didn't change the low end response, since I swapped cams the same time I changed intakes.
The dominator is awesome. It's VERY similar to the megasquirt in terms of capability and tuning methodology, but it's just so much more refined and user friendly.
Blows the stock ECU junk out of the water.
I like it so much in fact, that I just bought another one for a project car I'm working on
Turbo diesel
Old 07-28-2014, 09:44 AM   #442
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
[QUOTE=
I like it so much in fact, that I just bought another one for a project car I'm working on [/QUOTE]
C'mon... what is it?
Tom Vogel is offline   Reply With Quote
Old 07-28-2014, 10:34 AM   #443
Wasted Income
Boosted Member
64 Buick Skylark.
I've already got the LS6 from a CTS-V built for it, and the 4L80E ready to go. It's getting turbocharged as well
Much more longer term project. It's getting taken down to bare metal to repair a couple rust spots, and a fresh paint job.
Turbo diesel
Old 07-29-2014, 09:25 AM   #444
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Love the old Buicks. That will be sweet.
Old 07-29-2014, 09:32 AM   #445
66LSx
66LSx's Avatar
Buick looks straight and solid...
Goodies to be had for the 64-72 A-body should/could make this thing nasty!
pro-touring?/OEM outside-nasty inside?/drag? whats the project outcome and scope on this one? [too many questions too soon?]
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
Old 07-29-2014, 02:48 PM   #446
Wasted Income
Boosted Member
Not really sure what direction this one will go. Probably a bit pro-touring with some suspension and brake upgrades, with a bone stock interior, and some stickey tires for impromptu stoplight action.
Kind of a well rounded street car/cruiser/bruiser.
Turbo diesel
Old 08-13-2014, 04:43 PM   #447
Wasted Income
Boosted Member
Guess I haven't updated this in awhile...the ol' Family Truckster is living up to it's name. My wife and I welcomed our son to the world about 3 months ago. He's already been out cruising topless with us a few times As you can tell, horsepower puts my daughter to sleep. lol
Turbo diesel
Old 08-13-2014, 05:11 PM   #448
lt155ruck
lt155ruck's Avatar
Congrats on the addition!
lt155ruck is offline   Reply With Quote
Old 08-14-2014, 11:21 AM   #449
RocketChevy56
Certified BFH Operator
RocketChevy56's Avatar
Congratulations on the kiddo!!
- 1969 swb C/10 fleetside -LSx swap and Resto in progress
LQ4/TH400/Ed Curtis cam/Pro Flo intake/Brian Tooley Goodies ..... a couple snails may be trying to crawl into my engine bay...
-1997 Z/28 - LT1/T-56 - Bolt ons, 9 inch, built trans/clutch and on the bottle
RocketChevy56 is offline   Reply With Quote
Old 09-04-2014, 10:33 AM   #450
Wasted Income
Boosted Member
Spun a rod bearing this summer......lets try this AGAIN! lol.
Turbo diesel
