Old 05-13-2014, 10:31 AM   #26
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Water leaking into cab....couple possibilities
how about here?AC cab
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-13-2014, 10:44 AM   #27
kikkegek
kikkegek's Avatar
Where? Can you point it out?
kikkegek is offline   Reply With Quote
Old 05-13-2014, 07:06 PM   #28
motornut
78K & 79C Jimmys
motornut's Avatar
It seemed to come from the top couldn't see it , then saw the hole, when the fender came off.
John
Old 05-13-2014, 11:31 PM   #29
mrolds88
Originally Posted by rs72z View Post
If you can stick your finger through the sunvisor hole and feel moisture i would say it's coming from the cab lights.
I thought there was jclips or maybe plastic inserts that went into the roof where the screws thread in.
You might need to use a skim coat of clear silicone on the bottom of the lights also to stop the leak.
I have a parts truck with cab lights that i could take one off of and check if need be.
My cab lights are the problem on my crew cab. My solution is to drill out the holes in there and install rivnuts. Then replace the hardware with stainless machine screws. I used some socket head stainless cap screws. No worries about stripping them out. I think they are 6-32 thread.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-14-2014, 03:18 AM   #30
kikkegek
kikkegek's Avatar
could you point them out with a marker? arrow?
@mrolds88: that is also something I am considering....to many options, hahaha
Old 05-15-2014, 01:23 PM   #31
motornut
78K & 79C Jimmys
motornut's Avatar
87 Cab/hinges ,with AC has no foot vent inside there.
I first sealed under the rubber hinge seal(A),
still had water come into the drivers foot area.
seems the seal behind (B) holds in the dirt behind the fender
saw the hole (C) after and figured it was spraying in there
John
Old 05-15-2014, 01:45 PM   #32
kikkegek
kikkegek's Avatar
ok, thanks
