Old 01-06-2004, 12:27 AM   #1
shortbed70
shortbed70's Avatar
200r4
I was wondering if anyone is running this trans in there trucks? Ive got a 65 shortbed and I drive on the highway to get everywere I go. I've got a 3.73 rear and 25.5 in tall tire and I'm reving the motor a little tight to get to 70. Will these trannies hold up to daily driving in a heavy truck? I'm getting one out of an 87 monte carlo ss with a 305.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-06-2004, 12:59 AM   #2
newsalem2004
Your probably a lot better off getting a 700-R4. They are a little beefier.
newsalem2004 is offline   Reply With Quote
Old 01-06-2004, 01:11 AM   #3
cdowns
cdowns's Avatar
i have the 200-4R tranny for 21/2 years now have put close to 40thousand miles on it without a problem. b-4 installing it was builtup at a tranny shop and it is actually rated for more power than a 700R4. if fit right in no cutting driveshaft the only mod was relocating the tranny crossmember to the th400 position
Old 01-06-2004, 01:45 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The gearing is better suited in the 200-4R also.
I hope to go to one of these one day in teh caddy longhorn. Asuming it ever leaves the driveway under its own power.
Old 01-06-2004, 01:56 AM   #5
ABHaulR
ABHaulR's Avatar
i have a 2004r in my sub. i run 40's with 4:56 a stock motor with 340,000 miles on it. drive it daily, its been all the way to Utah from Ca. without any problems. oh by the way mine is stock no changes.
Dwayne
72' GMC Suburban 10 1/2" of Lift, 40" Tires! Waiting for restoration
67' Chevy, What to do???
And Bad Ass American Bulldogs!
ABHaulR is offline   Reply With Quote
Old 01-06-2004, 03:25 AM   #6
Rooster's 67
Rooster's 67's Avatar
40 series tires or 40 second in the 1/8th:1/4 mile?
Ihope the tires are what you are refering to.
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 01-06-2004, 10:10 AM   #7
Iron-Butt
454 club
Iron-Butt's Avatar
I have the 200r in my 63. I run 308 gears and 17 inch tires. I have about 10,000 miles on it with no problems. It pulls a trailer with a harley on at as well as a harley in the bed of the truck.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 01-06-2004, 11:48 PM   #8
shortbed70
shortbed70's Avatar
I think I'm gettin a good deal at 225 for tranny converter and flywheel. All I have to buy is the lockup kit from summit or someone. I plan on building a 383 later this year but I will adress the rebuild part at that time. I just want an overdrive that I dont have to sppend alot of money on and dont have to shorten the driveshaft. Hey ironbuttlcmc any pics?
Troy
Big Red Dog build
Old 01-07-2004, 01:19 AM   #9
Longhorn Man
Your best bet is to get a kit that addresses the TV cable properly too. If the line pressure is not right, you'll be doing it again in 10,000 miles.
bow tie overdrives sells a kit that has recieved high praises on this board and in the magizines.
Old 01-07-2004, 02:13 AM   #10
Solver
Solver's Avatar
So your saying that the 200r4 is basically a direct bolt in in like a 350 truck?What exactly are the mods needed. I have 1/2 ton 72 with 350/th350 tranny now. If it doesn't need driveshaft shortened are the splines and everything else the same. If all I need to do is slide the tranny crossmember to th/400 and pickup a tv cable I think even I could handle that. What models and years of vehicles do I look for to find the 200r4.
Solver
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 01-07-2004, 03:06 AM   #11
ABHaulR
ABHaulR's Avatar
by the way i was refuring to 18x39.5x16.5 inch super swampers on my sub. i got my tranny from pick a part on a half off day. the tranny and converter cost me 40.00 bucks. the splines on the tail shaft of the 2004r are the same as the th350. you just need to move your cross member back. it also uses the same trans mount as the th350. mine is out of a 88 olds. they are also in the buick grand nash's. you have to get a carb linkage that has the tv cable hookup on it. you'll need the converter bolts from the doner car or you need to get some from a parts house. the bolts for the 2004r are metric and the th350 are sae. the flex plate from your th350 will work for the 2004r, so no need to look for another one.
hope this helps you make you mind up.
Dwayne
Old 01-07-2004, 08:11 AM   #12
Longhorn Man
One thing to double check, the @00-4R was in many BOP aplicaions, and does have a dual bolt pattern, however, not all the converters will work.
Some engines had a raised mounting point on the flywheel...while others had flat mounting on the flywheel. Manke sure the converter you get is off of a flat flywheel.
