Old 05-16-2014, 09:33 AM   #1
1963c-10
1963c-10's Avatar
differences in 60-66 trim packages for chevy
Done a lot of searching in the forum and the Faq's with no answer. Im using the 60-61 bed trim on my 63 fleet side. I know the 62-66 used different cab and bed trims than the 60-61, but my question is.....will the 62-66 upper trim pieces for the cab and fenders match the 60-61 bed trim. 60-61 had the single trim piece that ran down the fender and cab and 62-66 had the dual trim on the cab and bed. The uppers can be purchased through Mar-K separately. Any help appreciated.
I know the mounting locations are different....they sit lower on the 60-61 trim packages and the front fender trim would have to be shortened...but not a big deal. Main thing is the trim is the same size.
The 60-61 front fender trim was also 1 piece as opposed to the 2 piece front fender trim on the 62-66. So really the door trim is in question.
Pics for reference
1964 Short bed trailer
Old 05-16-2014, 11:33 AM   #2
1963c-10
1963c-10's Avatar
Re: differences in 60-66 trim packages for chevy
OK, found the 60-61 front fender parts....so just the door trim in question
Old 05-16-2014, 06:43 PM   #3
60-66
60-66's Avatar
Many differences, first the 60-61 is Stainless and narrower . Sort of has a raised line right down the middle of 60-61 moldings. 62-66 is Aluminum and the main pieces are wider. Nothing will interchange or theres nothing you can combine together to make it work either.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 05-17-2014, 11:04 AM   #4
1963c-10
1963c-10's Avatar
ok thanks...so i just need the 60-61 door trim to complete my set. thanks....the search continues
