Old 05-16-2014, 04:03 PM   #1
4x4K10
Np208 married to an sm465?
Found an sm465 thats attached to an np208. My 85 k10 has the 700r4/208 setup currently. The 465 in an 87 blazer with the hydraulic clutch. My question is if i were to get everything i need for the auto to manual swap can i use the 208 from my 700r4 and attach that to the 465 or do i need to get the t case along with the tranny? Thanks guys.
4x4K10 is offline   Reply With Quote
Old 05-16-2014, 04:18 PM   #2
mrolds88
Re: Np208 married to an sm465?
Someone else may need to chime in, but I believe that they used different input shaft spline counts in the autos and the manuals.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 05-16-2014, 04:27 PM   #3
mongoose
mongoose's Avatar
ive been looking for a set up for a project what ive read is the 350/700 is 27 and the 465/400 is 32 spline.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 05-16-2014, 06:23 PM   #4
4x4K10
Thanks a lot guys, i will have to just buy the tcase with the tranny. now my next question would be can i use my current drive shafts with this transmission? i know the 465/205 is shorter so i would need longer drive shafts but is that the case with the 208 also?
Old 05-16-2014, 09:34 PM   #5
mrolds88
You may be able to use your driveshaft's. I am pretty sure the adapter for the 465 is longer than the 700's. Measure from the block to the back of your transfer case before you go to pull everything.
93 K2500 xcab 6.5TD
Old 05-17-2014, 06:36 PM   #6
4x4K10
Well i went and pulled everything today. Got the driveshafts just to be safe. And its a hydraulic setup, which will be very nice.
