Old 05-16-2014, 08:19 PM   #26
pimpston65
pimpston65's Avatar
Re: points swap for PerTronics
thks i will do that tomorrow and see whats the deal cuz when its running it sounds strong and no misses or anything.
pimpston65 is offline   Reply With Quote
Old 05-16-2014, 08:25 PM   #27
j.kirn
points is all I use and do not have any problems
j.kirn is offline   Reply With Quote
Old 05-16-2014, 09:05 PM   #28
65CowboyCaddy
I put a pertronix in my 250 a few months ago. I had trouble with starts, found that the resistor wire was the problem. Run a wire from the pos side of battery to the coil. See if it will start, won't be able to shut off until wire is disconnected from battery or coil. Search converting to hei.
65CowboyCaddy is offline   Reply With Quote
Old 05-16-2014, 09:08 PM   #29
pimpston65
pimpston65's Avatar
ima stick with points for now, gonna keep it stock looking for HEI unless they make a type that looks like stock with points, but HEI
Old 05-17-2014, 07:03 PM   #30
pimpston65
pimpston65's Avatar
well i got the 283 with points running. first i wanna say thks for all the input!!!! turns out i had poor ground and positive connection, i was using jumper cable off the battery to the starter and block. it worked a few times, less often then more. so i keep going over everything and brought out my fancy NOS packard power and ground wires and attached it and hooked up a battery charger to the battery and BAM!!! it fired right up. shut it off BAM!!! starts up everytime. the engine runs soo smooth no shakes, knocks, vibration,smoke nothing, just smooth all the way up the rpm band. also i checked the compression with the starter ground properly. i have 105psi throughout all cylinders, 55pounds of oil pressure and stay'd at 195 degrees on the temp gauge, guess the guy i bought it from really did freshly rebuild it. so the moral is ck the simple stuff first!!!
Old 05-18-2014, 12:13 AM   #31
Sharps40
Great news....now get er done an runnash#toutta it!
Sharps40 is offline   Reply With Quote
Old 05-18-2014, 01:09 PM   #32
pimpston65
pimpston65's Avatar
dats the plan!!!
