Old 05-16-2014, 08:55 PM   #1
Bullett
Light switch knob removal?
I need to remove my new light switch that I installed a couple weeks back because I will be replacing the wiring harness. For some reason, I can't seem to get the knob to separate from the switch. I remember you need to pull the knob all the way out, to the "lights on" position and then push a release button. This switch that I installed, which I believe is an aftermarket switch even though it looked exactly like the original, doesn't seem to have any release button. There is a spring loaded type button on the side opposite the side where everything plugs in. Is that the release button?
Bullett is offline   Reply With Quote
Old 05-16-2014, 09:00 PM   #2
jtrichard
Re: Light switch knob removal?
yes thats it ....pull the knob out and push the little pin in ....some times you kinda have to wiggle everything some
jtrichard is offline   Reply With Quote
Old 05-17-2014, 02:00 PM   #3
Woogeroo
early classic - tach. install article
it's two or three pages, check the links at the bottom of the page.
I only include it as it has photos and explains the head light switch removal process and reinstall.
remember to disconnect the battery too.
-W
Woogeroo is offline   Reply With Quote
Old 05-17-2014, 02:32 PM   #4
66LSx
66LSx's Avatar
Not a 60-66 but same concept applies....
https://www.youtube.com/watch?v=wxZIjY8EbZ8
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
