Old 05-18-2014, 03:05 AM   #1
revitout
rear wheels not centered
I have a shortbed crew on a lengthened76 suburban chassis. The rear wheels need to move foward 1" to be centered in the guards. It has a longer hanger at the back and a small notch in the bed cross member. I'm trying to find out what is the easiest way to move the diff forward. Can you slide the lower leaves forward or are they all pinned together. The front leaf mount bracket is welded to the chassis.
revitout is offline   Reply With Quote
Old 05-18-2014, 05:07 AM   #2
BADAZ chevy guy
BADAZ chevy guy's Avatar
Re: rear wheels not centered
Don't know what the "Easy" solution is, but if you move it forward you'll need to shorten the drive shaft as well. Worth it? Hmm!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182
700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236
BADAZ chevy guy is offline   Reply With Quote
Old 05-18-2014, 05:21 AM   #3
revitout
Shortening the drive shaft is no problem. It just don't look right with the wheels not centered!
Old 05-18-2014, 09:13 AM   #4
J Knight
J Knight's Avatar
Remove the rear axle and drill a new hole on the spring perch 1in off the center hole. That's the easiest way to move the axle.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 05-18-2014, 09:31 AM   #5
v30crewcab
v30crewcab's Avatar
yes that
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-18-2014, 10:15 AM   #6
79Betty
79Betty's Avatar
What about ORD zero rates?
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 05-18-2014, 10:16 AM   #7
v30crewcab
v30crewcab's Avatar
they add an inch of lift
71 longbed 5.3 4l80
Old 05-18-2014, 05:52 PM   #8
revitout
thanks John, that sounds alittle easier than cutting and moving the front mount!
