Old 05-18-2014, 12:01 PM   #1
TobyArnot
Quit if it's not FUN!!!
TobyArnot's Avatar
Need some advice-New Crate motor
O.K. , I know this is not uncommon. I have seen this before, but I need some advice. My new crate motor has a with new Edelbrock intake with APR intake bolts, Fel-Pro gaskets, etc. The two center bolts on both sides are seeping oil up around the bolts. I used ARP thread sealer on all the bolts and carefully torqued the bolts. I really would like to stop this oil leak on an all new engine. Assuming (I know that's dangerous) the thread sealer is doing it's job, is it possible the the oil is seeping due to the holes in the intake. I am going to pull the bolts out tomorrow and clean the threads carefully and re-seal with the thread sealer. Would it help to put a small ring of RTV sealer just below the heads of the bolts or maybe add some SAE flatwashers? I have a new PCV valve on one valve cover and a new push-in breather on the other. Is there that much crankcase pressure to makes the leaks?
MY MOTTO:
Eat it all up, Wear it out,
Use the last few drops,
Spend all you've got,
Late in life, you'll think of the things you didn't do, not the things you did. - Get out and experience life !
Robbie Robinson a.k.a. TobyArnot (Toe Bee or not toe bee)
TobyArnot is offline   Reply With Quote
Old 05-18-2014, 12:13 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Need some advice-New Crate motor
Don't know if it makes a difference... but edelbrock makes their own gaskets specific to each intake. May want to start there?
The PVC set up described is what myself and many other people run, so that should be fine.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-18-2014, 12:46 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
In additon to what is mentioned above i would spray a littlet brake parts cleaner into the threads on the head to rinse the oil off inmorder to get a good seal and reseal as mentioned above.
WIDESIDE72 is offline   Reply With Quote
Old 05-18-2014, 03:29 PM   #4
dan42
dan42's Avatar
I have the same problem on my crate motor, have tried to seal the bolts to no avail so far. Are there any fail safe methods tomstopmthis problem anyone knows of?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-18-2014, 04:09 PM   #5
70cst
70cst's Avatar
Ttt
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 05-18-2014, 06:20 PM   #6
Wrenchbender Ret
I have never figured out why this happens but it does. I took out the bolts & cleaned the holes like Wideside says & used RTV on them. That fixed 3 of them the first time & I did the fourth one again & that worked.
Wrenchbender Ret is offline   Reply With Quote
Old 05-18-2014, 07:29 PM   #7
WIDESIDE72
WIDESIDE72's Avatar
I have also heard of using a rubber o ring under the head of the bolt. I would assume you would need to lube the o ring to keep it from tearing.
Old 05-18-2014, 08:44 PM   #8
asolde
asolde's Avatar
I use high temp RTV on my bolts. Seems like the bolts on the drivers side center intake are the ones most prone to leak.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
