Old 05-19-2014, 08:13 PM   #1
3drburb
Drop Spindles #
Hello, I have bagged my 72 1/2 ton suburban and would like to add drop spindles.
Do anyone have a product # for a set of 2 or 2.5 inch spindles that does not require changing ball joints or other parts?
DJM or Western is what I would like to use.
Thanks for the response.
3drburb is offline   Reply With Quote
Old 05-19-2014, 09:31 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Drop Spindles #
For a direct bolt on spindle, make sure you get a 71-72 specific spindle.
The board Vendors should be able to help you.
Otherwise look at Summit Racing.
Keith
Convert to disc brakes.
Old 05-20-2014, 11:02 AM   #3
3drburb
Re: Drop Spindles #
Thanks, for your help.
Old 05-20-2014, 11:39 AM   #4
lolife99
lolife99's Avatar
Re: Drop Spindles #
Choices from Smmit Racing since no Vendors replied,...
http://www.summitracing.com/search/y...drop%20spindle
Keith
Old 05-20-2014, 03:10 PM   #5
3drburb
Re: Drop Spindles #
So I guess that the 2" drop spindles will be the safest way to go with my wheels. 15x7 fronts and 15x8 rears.
Thanks again.
Old 05-20-2014, 03:39 PM   #6
lolife99
lolife99's Avatar
Re: Drop Spindles #
Thanks again.
Just remember,... that CPP's MODULAR 2" drop spindle require a brake caliper braket at an additional expense.
There are 2 different brackets.
One for 12" rotors (stock), and one for their larger 13" rotors when you use CPP's "Big Brake" kit.
This one is for the 12" rotor.
http://www.summitracing.com/parts/cl...del/c10-pickup
Personally I would just run a 2.5" drop spindle with the built-in /cast-in caliper bracket.
Belltech, Western Chassis, McGaughy's or Early Classic Enterprises would be my choice.
Keith
Old 06-08-2014, 10:32 AM   #7
3drburb
Re: Drop Spindles #
Thanks Lolife99 for your help with this. I got the CP4S3 drop spindles from summit.
Thanks again.
Old 06-08-2014, 12:29 PM   #8
lolife99
lolife99's Avatar
Re: Drop Spindles #
Man that looks good!^^^
That's low.
Air ride???
Keith
Old 06-08-2014, 12:54 PM   #9
3drburb
Re: Drop Spindles #
That's low.
Air ride???
Thanks, it's has bags from AVS, 2" rear blocks from Boris, 2.5 drop spindles, 450C Vaiar compressor with a 4 path Analog System setup. The picture isn't completly aired out, but I will be adding a c-notch soon and removing the rear bags hats.
It also has front and rear swaybars.
Just a simple set for a better ride.
Old 06-08-2014, 01:01 PM   #10
3drburb
Re: Drop Spindles #
That's low.
Air ride???
It also has front and rear swaybars and front and rear shock reloctors.
Just a simple setup for a better ride.
