Old 05-21-2014, 04:17 PM   #1
NastyBuzzard
NastyBuzzard's Avatar
Can you tell if this is a L33??
I have a chance to purchase complete 5.3 dropout from a 2005 Yukon for $500. 110k miles. He sent me a pic and it looks like an aluminum block or am I nuts?
NastyBuzzard is offline   Reply With Quote
Old 05-21-2014, 04:56 PM   #2
Fitz57
Fitz57's Avatar
Re: Can you tell if this is a L33??
I cant tell from your pic. Thought the L33 only came in 05, 06, 07 extended cabs. Get the vin number and do a vin number check. The eighth digit in the vin should be a B I believe.
Fitz57 is offline   Reply With Quote
Old 05-21-2014, 04:59 PM   #3
NastyBuzzard
I wish I could. It came out of a 05 Yukon that a tree smashed from ice storm a couple months ago. All I have is serial #s from ECM. Apparently owner is either too lazy or isn't smart enough to go stick a magnet on it for me or give me head casting #s or look at rear of the block... If he wasnt a couple hours away I'd just ride over.
Old 05-21-2014, 06:50 PM   #4
akdg87
akdg87's Avatar
it appears to be an aluminum block (unless it is dirty?).
BUT the L33's in trucks that i saw were equipped with electric fans.
build thread
1955 cameo turbo lsx
1993 K1500 Blazer 5.3/4L80e
2009 CTSV Sedan
akdg87 is offline   Reply With Quote
Old 05-21-2014, 06:52 PM   #5
NastyBuzzard
interesting!! its driving me a lil nuts wondering.
Also anyone know where I can buy new intake bolts for 4.8/5.3 stock 01 intake?
Old 05-21-2014, 09:55 PM   #6
NastyBuzzard
Old 05-21-2014, 11:05 PM   #7
tfi rcing
Unless the aluminum blocks were coated black-that is likely an iron block.
tfi rcing is offline   Reply With Quote
Old 05-22-2014, 12:09 AM   #8
69chevytrucker
69chevytrucker's Avatar
copper ground wire going to block would mean iron block in my opinion aluminum wouldnt
be grounded strait to it
69chevytrucker is offline   Reply With Quote
Old 05-22-2014, 12:33 AM   #9
littlevictories
aluminum conducts electricity just fine. they ground the harness to aluminum heads...
littlevictories is offline   Reply With Quote
Old 05-22-2014, 06:32 AM   #10
NastyBuzzard
Thanks guys! Now about those intake bolts... Or the intake bolt gasket.
Old 05-22-2014, 08:37 AM   #11
Wasted Income
Boosted Member
Wasted Income's Avatar
If the price is right, I'd buy it whether it was an aluminum L33 or not. All the 05+ (and SOME 04) engines have the stronger dimple rods and floating pin pistons. They're a great shortblock to make some power with.
Any parts store, rock auto, ebay, etc can get you intake gaskets.
Intake bolts:
http://www.autopartswarehouse.com/sh...rado_1500.html
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 05-22-2014, 08:44 AM   #12
NastyBuzzard
Intake bolts:
I already have a donor 2001 silverado 4x4 ext cab but it has around 150k miles and turned out to be a 4.8, I am doing the swap to a 1987 GMC V1500 4x4.
I was just shopping for a donor block to test fit but was really wanting to find a lower mileage 5.3 to swap the 4.8 with. I talked him down from $750 to $500. I am seriously considering getting it. I am wondering if I can just drop the "longblock" into the 2001 chassis and fire it up and make sure everything runs correctly, just swap everything from the 4.8 onto it since I have a 2001 and its a 05 engine, I'd need to use the older intake for the egr/return line.
What do yall suggest?
Those intake bolts dont look correct? Also i would need 10 not 8. I cant find any parts store that carries them.
Is it at all possible to just find the rubber grommet on them?
Here are bolts in question:
Old 05-22-2014, 09:07 AM   #13
littlevictories
i bought a set on ebay, like $20
Old 05-22-2014, 09:09 AM   #14
NastyBuzzard
I've scoured ebay and found nothing.. Maybe I am searching for the wrong thing.
So whats the vote? Drop the $500 on the complete engine w/ ecm 100k miles. Upgrade from the 4.8 to the 5.3? I have been leery of the torque the 4.8 will have in my 4wd truck.
I have the $, it isn't in the budget.. It will slow my build down a lil bit if I do make the purchase.
Old 05-22-2014, 09:09 AM   #15
Wasted Income
Boosted Member
Sorry about the bolts link...I saw that pic was wrong, but figured it was just a stock photo....lol.
I've got a couple spare 5.3/6.0 intakes sitting around the shop. I'll send you the bolts for $20. PM me if you want them.
I've swapped 7 junkyard LS motors in my time, and never once have I had a problem with one. I wouldn't waste your time swapping it into the donor truck to "make sure it runs". lol.
Regardless, $500 is a great price for a 5.3 that is that complete.
Yes, the 2001 intake will swap to the 2005 engine no problem...which is good, because you'll need a place to mount the throttle cable bracket if you're staying DBC. I would delete the EGR nonsense when you have it tuned, and plug the hole in the intake. You can run the passenger side manifold from that 2005 engine, which won't have the EGR boss on it.
Turbo diesel
Old 05-22-2014, 09:11 AM   #16
Wasted Income
Boosted Member
I bet you'd be able to sell that 4.8 for about what you're getting the 5.3 for.
Turbo diesel
Old 05-22-2014, 09:16 AM   #17
NastyBuzzard
Anyway to get them to SC by friday? If so, DEAL!! Or saturday to be honest.
Here is my build thread... I am not doing just a typical standalone swap..
http://67-72chevytrucks.com/vboard/s...d.php?t=627161
I think I may just jump on this 5.3 and let my bank account hurt for a month or so...
I do plan to delete egr.. I think I need a 1 3/8" freeze plug though. I want to get pcm done to eleminiate egr and cats..
You really think I could get that much $ from a 4.8?? I'd probably have to sit on it for a while to find the right buyer.. Makes it even more tempting!!!
Old 05-22-2014, 09:39 AM   #18
Wasted Income
Boosted Member
By friday...you mean tomorrow?? lol. No. I'm at work and all that stuff is at home. I could ship it out tomorrow though if you want them.
Not sure what LS stuff is going for there....but it's climbed in price a BUNCH around here...I had a buddy about 7 years ago that literally could not give away a 4.8. lol
http://chicago.craigslist.org/nwi/ptd/4477839579.html
http://terrehaute.craigslist.org/pts/4465915423.html
http://madison.craigslist.org/pts/4480105786.html
There's a pretty good spread on prices, but if nothing else, you should be able to make at least half your money back, if not all of it. The CORE price around here is $300 on ANY LS from my local junkyard...
Turbo diesel
Old 05-22-2014, 09:46 AM   #19
Clyde65
Clyde65's Avatar
There is nothing wrong with a 4.8, compared to a 5.3 there is only 25-35 HP difference. the 4.8's run real well with turbos ( not that the 5.3's wont tho) and they are cheaper to get than the 5.3 usually.
I am running a 4.8 out of an 05, cam, CAI, performance tune, headers and it runs hard and still gets @20MPG, double the HP my 350 had.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-22-2014, 09:47 AM   #20
NastyBuzzard
Very nice and reassuring!! Although may save the 4.8 for my 79 TA !! Nah I don't really have anywhere to store it. You may have convinced me, my bank account will suffer, plus dont tell the wife hahahaha. I could also sell wiring harness off it maybe and pcm from the 4.8..
Do I just swap in the 5.3 ecm, or is it more complicated than that?
I found GMs part # for the bolts w/grommets (grommets dont sell seperately). Its GM #89017368 and they are around $20 for 5 of the bolts and I need 10 unfortunately.
Old 05-22-2014, 09:53 AM   #21
NastyBuzzard
My concern isn't really the HP from the 4.8. This is going into my 87 LWB 4x4 truck that I use mostly for towing/hauling, picking up parts or materials. I don't tow anything really heavy or anything tho. I just remember my 01 silverado I owned about 5 years ago (single cab/stepside or sportside) had the 4.8 and it was a great lil truck but was afraid of hills and not real well at towing... May have had 3.08 gears tho not sure.
Although 20MPG is what Im shooting for!
Old 05-22-2014, 10:09 AM   #22
littlevictories
threadjack:
do the 2005+ DBW intakes have the bosses for the brass inserts or are they gone? I have pulled and pressed-in those inserts a couple times on older stuff---2003ish
Old 05-22-2014, 10:54 AM   #23
Wasted Income
Boosted Member
threadjack:
I believe they are gone, but I could be wrong. I think i have a 2007 LQ4 intake kicking around somewhere...i'll take a look.
Turbo diesel
Old 05-22-2014, 11:00 AM   #24
NastyBuzzard
Thats why I love this forum.. Nice guys all around.
Old 05-22-2014, 12:03 PM   #25
ls1nova71
ls1nova71's Avatar
threadjack:
All of my Gen3's have had them, up to and including my 2007.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
