Old 05-23-2014, 09:48 AM   #1
JMac11
JMac11's Avatar
Drive Shaft ???
Sawpped from a 10 to a 12 bolt in my 84 SWB 4x4. Didn't think to check drive shaft length, looks like I have ALOT of yoke hanging out of the transmission. 12 Bolts shorter/need longer driveshaft?
JMac11 is offline   Reply With Quote
Old 05-23-2014, 10:39 PM   #2
junksaver
Re: Drive Shaft ???
I did that same swap about 15 years ago in a mid 80's blazer. I used the same driveshaft, but I had to get a conversion u-joint as the rearends had different yokes. If you still have the other rearend you can always measure the distance from the yoke to the centerline of the rearend on both of them just for a comparison. I think it should be close enough to not make a difference in your drive shaft length.
68 4wd Stepside
69 2wd Stepside Project
71 2wd Blazer Project
72 2wd 3/4 Ton Project or Parts?
73 4wd Blazer
junksaver is offline   Reply With Quote
