05-23-2014, 06:08 PM | #126 |
Re: 1968 C10 5.3 swap, the easy way.
Car show on Sundays? I only knew about cars and coffee on Sundays. Can you pm me your#?
05-23-2014, 06:09 PM | #127 | |
05-26-2014, 11:40 AM | #128 |
05-26-2014, 12:40 PM | #129 |
05-26-2014, 04:26 PM | #130 |
That's weird that you're getting such bad mileage with the LQ4. My LQ4 Chevelle with 315 tires, gm hot cam, t56 and 3.90 gears gets 23mpg on the highway/ ~17 in town. I know it's a car and it's lower, but those wide tires don't do me any favors. No AC though.
Nice truck man. Im planning out my 71 GMC for my newly acquired 5.3/auto swap and I really like the way you did the mounts and AC. |
05-26-2014, 05:41 PM | #131 |
My 68 firebird with 4.10's, t56 and the 6.0 in that got 24 on the highway. These trucks are not aerodynamic in any way. My firebird would cruise at 90mph no problem. My truck needs a lot more gas input to maintain the higher speeds. I changed cams in the truck and got 17mpg on my last trip though.
06-06-2014, 04:43 PM | #132 |
x2! I'd love to see this truck in person
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
06-11-2014, 07:54 PM | #133 |
You said you ran dirty dingo engine mounts. Did you just use a dingo 1973+ mount on the driver side with the clam shell isolator and a different one on the passenger side? Did you have to get 2 sets of plates to do this? Curious since I cant really make it out in the pictures. Thanks.
06-22-2014, 09:18 PM | #134 |
Kvn1011
love the swap
post pics of your car when you get time
My Build Thead (Project Slow Motion) |
06-22-2014, 10:33 PM | #135 | |
07-06-2014, 05:28 PM | #136 |
chevy runs deep
Came out real nice bro thanks for all the info
RAIDER NATION 1969 c10 swb soon 2 b on the road... My LWB is a SWB now http://67-72chevytrucks.com/vboard/s...d.php?t=498241 |
07-09-2014, 07:37 PM | #137 |
Very cool! I plan on doing the same swap very soon the same way. Nice work!
07-10-2014, 01:31 PM | #138 |
what was the issue? - I've seen pics of people using them and want to use one with my 63' if at all possible.
07-15-2014, 01:07 PM | #139 |
my inspiration thread! the 350 i just put in my 69 a few months ago is starting to smoke at warm idle now...time to find a 5.3 and do a mild build but i plan on keeping it hooked up to my th400 unless i score a trans cheap as well. so dingo mounts and 73+ mounts and im guessin the factory driveshaft will work as long as the mounts are adjusted accordingly. lookin into the car intake and manifolds since im dropped 3" but plan to lay frame in the near future. *thumbs up*
07-18-2014, 08:00 AM | #140 | |
07-18-2014, 02:32 PM | #141 |
A LS1 tank will not fit between the frame rails unless you hack it up the frame up. Not worth it at all in my opinion. Also its not a flat tank on the bottom and will hang down.
07-18-2014, 02:49 PM | #142 | |
07-20-2014, 03:44 PM | #143 |
Truck and auto performance nut
Thanks....glad to here I'm not putting bad information out there!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
09-13-2014, 07:44 PM | #144 |
New updates. Installed a 8.8 ford rear end for cheap but strong limited slip. Also upgraded to a better flowing intake manifold out off a TBSS. Upgraded to 90mm dbw throttle body off a gto as well. Much more responsive and wants to spin the tires all the time.
09-13-2014, 10:26 PM | #145 |
What is the difference between the stock manifold vs the TBSS manifold? Also, what year is the GTO TB and did you have to re-tune?
09-13-2014, 10:42 PM | #146 |
Well its kinda confusing. My new intake is a GEN IV cathedral style head intake. Used on TBSS and all 5.3 and 4.8's. They look much different from the gen3 style and some testing has shown them to make more power than a LS6 intake. Ive read many conflicting tests though. I got mine cheap and wanted to upgrade to the 90mm DBW. It was easy to put a GTO DBW throttle body on mine due to the old style dbw I used(00-02). Same as the corvette. newer 2003-2007 DBW you need a 250$ signal modifer to get a gto throttle body to use.
09-13-2014, 10:47 PM | #147 |
Ah, got ya. I have 2011 dbw. Thanks!
09-23-2014, 12:38 PM | #148 |
How did you do the wiring on the compressor . Got a vintage air system going to start install
09-23-2014, 07:04 PM | #149 |
09-29-2014, 09:50 AM | #150 |
Did you narrow/widen the 8.8 to center the pumpkin (explorer)? Or did you use a Mustang 8.8?
I'm about to do the same and ditch the 12 bolt boat anchor. |
