Old 05-24-2014, 10:08 AM   #1
NC67Chev
NC67Chev's Avatar
Is a spare tire 1/2 smaller diameter okay?
I've used a spare probably 3 times in my life, 2 of which were a result of my wife jumping a curb Anyway, is there an issue with using a spare that is 1/2 inch or so shorter?
I could use the same size as is on the truck, but it would be nice to have it a little more narrow since I'm gonna keep it under the bed. Thanks!
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 05-24-2014, 10:10 AM   #2
luvbowties
luvbowties's Avatar
Smile Re: Is a spare tire 1/2 smaller diameter okay?
You oughta be plenty ok. Narrower would be fine also--remember how much narrower the space-savers are?
Sam
luvbowties is offline   Reply With Quote
Old 05-24-2014, 11:43 AM   #3
dsy1
Just be sure to use it in the front only if you have a posi or a locker in the rear.
dsy1 is offline   Reply With Quote
Old 05-24-2014, 12:25 PM   #4
swamp rat
swamp rat's Avatar
As stated above, don't use if you have a posi or locker, with a regular diff your ok for short hop until you get the other tire fixed.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-24-2014, 04:14 PM   #5
NC67Chev
NC67Chev's Avatar
Thanks guys! I figured it would be ok, but I wanted to check and make sure. I'd keep the 15" spare under there, but it won't clear discs and it's approx 2 1/2" smaller in diameter than the new 16's.
Old 05-25-2014, 07:57 AM   #6
BugzC10
BugzC10's Avatar
I'm looking for a 5x5 donut spare to carry. So you're saying that the 15" donut spare won't clear the disc? Only a 16"? Please clarify
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 05-25-2014, 09:24 AM   #7
NC67Chev
NC67Chev's Avatar
I'm talking about the original 6 lug 15" drum only wheels that were used up to '70.
