#251 |
Re: 5.3 swap build so far
for mounting your PCM, google up "s-10 pcm mount ls1"
its what i used. looks legit. |
#252 |
Mines mounted and gtg, thanks tho
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
#253 |
Using the truck as a dd, loving it so far, gotta do some minor things other than that awesome power
#254 |
You used the stock 04 manifolds right? Any frame notching needed?
What kind of mpg you getting with the 5.3? |
#255 |
Ya used the stock manifolds, had to do a little cutting, not sure what my mpg's are yet, just got the speedo calibrated the other day
#256 |
I just got that pcm bracket looks like it will work real nice
Trying to get thru my LS swap ![]() |
#257 |
#258 |
![]() Join Date: Sep 2005
Thats wha i hsve got it for 15.99 from my local dealer
#259 |
Shop around!!! I'm always looking!!!
#260 |
got the speedo calibrated good the other day, its like 1 or 2 mph off, but works pretty good
#261 |
somewhere somebody on here ask me about my MPG'S, got a rough estimate today, putting around town and just going to school, getting on it from time to time I'm getting somewhere around 20 mpg's or so, ill have more accurate numbers here soon...just gotta get gas and do the math
#262 | |
#263 |
Ya man
#264 |
so far my mpg's are between 16 and 20, i need to quit showing off!!!!
#265 |
Thats pretty damn good considering yours is a four wheeler and you got those big ole meets on there
#266 |
True man, not bad at all I don't think
#267 |
well mine should do even better since mine is 2wd with stock 235/75/15s on it.
1983 C10 Silverado 5.3 swap 1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122 2001 BMW 530i 5 speed 2019 Nissan Titan SV Midnight 1979 Datsun 210 4 door 1980 Datsun 120y(back home in Trinidad) |
#268 |
It might, a lot of it depends on the gear ratio, tune, and how you drive
#269 |
what gears are u running again? mines 3.08
#270 |
4.56's...had 2.73's...they didn't like 35 inch tires
#271 |
I want to go with 3.55 or 3.73 when i have some money
#272 |
I'd do 3.73...tranny depending
#273 |
meowMEOWmeowMEOW
Depends on your trans type and tire sizing, one may mathematically work out better for ya. 3:73 12-bolts are easy enough to find, so simplicity might lead you there.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#274 |
I'm running a stock 4l60e from an 02 truck and 235/75/15 tires.
#275 |
id say 3.73's would be good to go, should pull good, and not be too high on the rpm's at highway speeds
