Old 05-25-2014, 03:49 PM   #1
nathankershaw
nathankershaw's Avatar
Driver door stuck shut.
I searched and couldn't find a specific answer to this question.
1964 GMC.
My drivers door is stuck shut. Not totally shut but where it loosely rattles.
The truck has been stood since 1993 so PB blaster has been used
The mechanism pulls the 2 hooks away from the barrel that latches to the latch on the B pillar but that barrel doesn't seem to want to spin to let the door open.
I may just be seized but I wanted to ask if anything obvious happens to stop that barrel from spinning?
Thanks for any help and sorry for these annoying little questions.
nathankershaw is offline   Reply With Quote
Old 05-25-2014, 10:51 PM   #2
63burban
Chevy addict
Re: Driver door stuck shut.
Did you try prying it open?
63burban is offline   Reply With Quote
Old 05-25-2014, 11:14 PM   #3
nathankershaw
I was hoping to try and see if anything goes wrong alot with the door catches.
I'm hoping obviously to not to have to resort to that.
From the inside I've put a fair amount of pressure and rattles it back and forth.
Old 05-25-2014, 11:23 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I ran into this once on my '65 truck. I had to use a pry bar to GENTLY pry up the door from the rocker while I had my wife pushing the button and pulling on the door. It finally popped open. I then readjusted the door striker so it wouldn't stick anymore. Worked perfect. Remember, up with the door, not trying to pry it open.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 05-26-2014, 07:11 AM   #5
tazattitude
tazattitude's Avatar
Is there anything you can do from the inside? Possibly take off the door panel and work on the latch from the inside of the door.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 05-26-2014, 08:28 AM   #6
63burban
Chevy addict
I just bought a 66 that the passenger door wouldn't open, even shouldering the door from the inside. Pushed the button on the outside and gently nudged it with a screw driver and it popped right open. After that it opened and closed fine but it needs a little oil. I have run into this situation several times with trucks that sit outside a long time.
Old 05-26-2014, 11:03 AM   #7
nathankershaw
Yeah the door panel is off.
OK. I'll try some levering today
Old 05-28-2014, 02:47 PM   #8
1963c-10
1963c-10's Avatar
Did you get the door open?
1964 Short bed trailer
Old 05-28-2014, 04:42 PM   #9
nathankershaw
Yeah just got it open yesterday.
Prybar and a couple of friends did the trick!
I tool the lock mechanism out and the "star wheel" that latches onto the latch is completely seized.
It started turning after about 24 hrs of spraying with PB blaster.
1964 GMC 1502, 3/4 ton wideside.
Old 05-28-2014, 04:55 PM   #10
1963c-10
1963c-10's Avatar
Cool, glad its resolved!!
