Old 05-25-2014, 12:32 AM   #1
terbronco7
terbronco7's Avatar
Jerking while at cruise speed
No matter what gear I am in the truck wont stay at a constant cruise just jerks like I am goosing the throttle. Any ideas as to what may be causing this?
As always thanks everyone for the feedback.
Not sure of exact tranny but has granny 4 speed in it.
terbronco7 is offline   Reply With Quote
Old 05-25-2014, 08:29 AM   #2
63burban4x4
63burban4x4's Avatar
Re: Jerking while at cruise speed
Oh, you mean the TRUCK is jerking........
63burban4x4 is offline   Reply With Quote
Old 05-25-2014, 08:34 AM   #3
ncoonen
ncoonen's Avatar
Does the engine idle okay? Does it rev smoothly when you when you hit the throttle in neutral? This is sounds like the fuel bowl might be overflowing (bad needle/seat). Revving the throttle will hide the problem but it misbehaves when you try to run steady.
By the way, your thread title should win you a POTD award. (post of the day)
Good luck...ned.
'63 C10 long wide; '61 Corvair Lakewood; '74 BMW 2002tii; '89 BMW 325i, '49 Ford 8N
ncoonen is offline   Reply With Quote
Old 05-25-2014, 10:50 AM   #4
bosephus
bosephus's Avatar
bosephus is offline   Reply With Quote
Old 05-25-2014, 10:59 AM   #5
Snailed
Snailed's Avatar
It may be too lean at low load.
What it your air fuel ratio? My 350 won't do a light cruise much leaner than 15:1. Any leaner and it jerks. Maybe you have a small vac leak or the floats are too low?
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 05-25-2014, 05:41 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Didn't California pass a law against on-road jerking? ..... as well as Assisted On Road Jerking?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-25-2014, 10:51 PM   #7
63burban
Chevy addict
Possible water in the gas
63burban is offline   Reply With Quote
Old 05-26-2014, 10:38 AM   #8
Wrenchbender Ret
Some engines will run rough at part throttle because of excessive timing. Try driving with the vacuum advance disconnected. If it helps you may have to get an adjustable vacuum chamber & limit the advance.
Wrenchbender Ret is offline   Reply With Quote
Old 05-26-2014, 10:49 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
Check the fuel filter also. or just replace it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
