Closed Thread
Old 05-25-2014, 08:13 PM   #651
Chevy Fleetside
Chevy Fleetside's Avatar
Re: What did you do to your truck today part II.
Got the gauges mounted into the frame and have been wiring them up. Hope to have them mounted in the truck this week.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 05-26-2014, 12:24 AM   #652
mattbert56
mattbert56's Avatar
changed out the lifters and rocker arm locking nuts on the 292 today, need to figure out the low oil pressure issue now. :/
mattbert56 is offline
Old 05-26-2014, 10:28 AM   #653
TJ's Chevy
TJ's Chevy's Avatar
The original pump brand new when hot ran at 20-30 pounds..these engine do not require a lot of oil pressure. 40 pounds when cold is plenty...the original pumps are a low volume type...It isn't recommended to go to a high volume because camshafts have been know to break because of it. My 292 which is 48 years old internally and has 147k on it runs at 30 pounds cold and 15 pounds hot...plenty of pressure...If I was you, I would pull the pan..clean the pickup screen out and put a new stock pump in...they run as cheap at $30 bucks. And the ultimate oil for these is straight 30.
TJ's Chevy is offline
Old 05-26-2014, 12:58 PM   #654
65panelrat
65panelrat's Avatar
Got my Flowmaster 40 series "copies" installed, and dumped in front of axel. Sounds Nasty!
Bowties For Life!🇺🇸
65panelrat is offline
Old 05-26-2014, 04:10 PM   #655
jayoldschool
Moderator
Got the truck in the shop today! Started swapping out my control arms. All hardware came apart easily with a little help from the torch. Much easier without the bed!
One step closer to hitting the road. Exhaust and driveshaft next.
jayoldschool is offline
Old 05-27-2014, 03:41 AM   #656
mattbert56
mattbert56's Avatar
thank you for the tip, upon further investigation i boiled it down to the wrong length dip stick, and when the PO had it rebuilt, the oil pickup tube wasn't set at the correct height from the oil pan's bottom. so when the dip stick indicated "full" i was 1.5 quarts low on oil. when i would stop hard, or be facing down a hill, the oil pressure would bump up. going up hills it'd sink like a rock. oil was sloshing in the pan. added bit more oil and BAM! 45 -50 lbs when running cold.(little high cuz of all the Lucas). truck runs FANTASTIC now. ah hah! love when things are a simple fix. once again thank you for the help T.J MCCAULEY
Old 05-27-2014, 11:41 PM   #657
pimpston65
pimpston65's Avatar
finally made so headway on the bench seat cover, a pull here and tug there and itall look nice. the bottom part is on tomorrows to-do list
pimpston65 is offline
Old 05-28-2014, 01:33 AM   #658
Dillon Rock
Swapped out flasher switches today from the flarestart to the Roberk Co. Model 800 switch. Works much better than my flarestart.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline
Old 05-28-2014, 03:17 AM   #659
pimpston65
pimpston65's Avatar
i wanted a custom look, so i went with the "wallfall" front
Old 05-28-2014, 04:06 AM   #660
pimpston65
pimpston65's Avatar
ima add the front black vinyl piece, not the happy with the wallfall front. oh well
Old 05-29-2014, 06:45 PM   #661
markeb01
Senior Enthusiast
markeb01's Avatar
Finished my bumper bullet project:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 05-29-2014, 10:54 PM   #662
Softpatch
Softpatch's Avatar
Man i real like the look the buick hood vent pop with the mat black finish
are they real or stick on.?
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline
Old 05-30-2014, 02:59 PM   #663
pimpston65
pimpston65's Avatar
made a jig to lift the cab on the frame with only one person and one to guild. of course i was sweat'n the whole time while it was free from its cradle, it held. yeah!!!!!!!
Old 05-30-2014, 03:02 PM   #664
pimpston65
pimpston65's Avatar
made a gig to lift the cab on the frame with only one person and one to guild. of course i was sweat'n the whole time while it was free from its cradle, it held. yeah!!!!!!!
another view
Old 05-30-2014, 03:03 PM   #665
pimpston65
pimpston65's Avatar
another view
the jig
Old 05-30-2014, 03:46 PM   #666
markeb01
Senior Enthusiast
markeb01's Avatar
They're real 1954 Buick portholes (Ventiports). I added lights to them the glow dim when the parking or headlight circuit is on. The bright lights flash with the turn signals and 4 way flashers.
markeb01 is offline
Old 05-30-2014, 04:29 PM   #667
1963c-10
1963c-10's Avatar
Nice jon Mark.....looks killer!!!!
1964 Short bed trailer
1963c-10 is offline
Old 05-30-2014, 04:30 PM   #668
1963c-10
1963c-10's Avatar
Seats looking good....I'd go with the black vinyl on the front too. I think it'll look much better. And nice job on the cab lift!!
1963c-10 is offline
Old 05-30-2014, 04:34 PM   #669
Grizz1963
Grizz1963's Avatar
Not quite "done" but part of the process.
Tonight I am the proud (???) owner of £436.00's worth of 2 and 2-4 inch lowering joy for the truck.
Mate Martin has bought the same for his '65 Long Fleetside.
The original lowering was done with an Oxy-Acetelyne torch at some point, leaving the truck a bit, well a lot, wallowy. Redneck engineering at its best with the springs unevenly bunched together.
So in line with having it as a functional driver when it is done, I decided this was another item that needs doing correctly. So spent the money importing the parts.
Martin needed a full set for his truck too, so when we saw the lot on sale by Brothers, we contacted the Brothers in the USA and asked about combined shipping....... the difference was $110.00 on the parts.
Of course you cannot get away from Customs, but the barstewards charge their VAT on the US courier costs too, which I think is a bloody cheek.
Anyway, I am happy that I have nitrous filled shocks with nylon bushes.
The springs weigh a ton, and look very good.
Still need to decide if I should get the springs powder coated, or just give them a coat of gloss enamel, as they are going out of site and this is a driver truck.
Picture of Joy.
There is a lot to be said for building two trucks in parallel. Loads of sharing of cock ups and spares, as well as helping each other out with bits.
On Sunday we have a marathon session planned with my truck and two of the motorbikes in my garage, as well as a petrol electricity generator and a Briggs and Stratton 190cc lawnmower that kicks back like a mule on its pull cord. Any ideas ??
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 05-30-2014, 04:37 PM   #670
Grizz1963
Grizz1963's Avatar
ABSOLUTELY 100% LOVE THEM DAGMARS.
Would love them and over riders on my truck too.
Old 05-30-2014, 04:39 PM   #671
pimpston65
pimpston65's Avatar
thks. i gotta take the sides off and make a new piece to make it look right good thing i stil have plenty black vinyl left
Old 05-30-2014, 05:49 PM   #672
hopped up
hopped up's Avatar
Nt much ,but it swapped on some new 51 Pontiac sombrero caps. I think it changes the look of truck in a good way
[IMG][/IMG]
hopped up is offline
Old 05-30-2014, 07:27 PM   #673
old cool
I attempted to tighten the drain plug on the bottom of my differential using the 1/2 portion of my ratchet. It requires what looks to be 5/8 inch "male" type fitting. Hit two stores and couldn't find one. Funny how the smallest things can tie you up.
old cool is offline
Old 05-30-2014, 08:52 PM   #674
Zxwill
Drive it. Need to take it down for new exhaust
Zxwill is offline
Old 05-31-2014, 01:24 AM   #675
Dillon Rock
[IMG][/IMG]
That looks real great man. Especially with the white walls.
Closed Thread
