Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-26-2014, 10:16 AM   #1
blazer2007
AN fittings all equal ?
I was going to plum my fuel with AN fittings and braided hose and was wondering if all the companys are good or are there some bad ones,Redhorse ,summit, earl,s etc.Is my first attempt
blazer2007 is offline   Reply With Quote
Old 05-26-2014, 10:29 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: AN fittings all equal ?
Just be careful and don't plau mix and match. I've had a lot of issues (leaks) when I mix Russell and other brands. By it's self Russell is top drawer stuff, but it just seems if I have a fitting that is a problem child, it's because I mixed brands of fitings / hose.
As a FYI Aeroquip makes Speedways and Slummits house brand. I've heard Earls makes the Jeggs house brand but have not had any to make a comparison.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-26-2014, 12:59 PM   #3
onebigdog
Fragola makes great AN fittings. Pricing is cheaper than Aeroquip and more than house brands. I believe they are made in the USA.
onebigdog is offline   Reply With Quote
Old 05-26-2014, 04:49 PM   #4
chevytruck1970
chevytruck1970's Avatar
I've always used aeroquip I really like the way their braided hose fittings work some of the other brands are much harder to put together imo.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 05-27-2014, 05:44 PM   #5
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
The jegs stuff seems to work very well. I used a bunch on my truck . Inspect each one for any minor issues on the seating area as some little marks etc will leak and that is a bad deal when you have to take stuff back apart.
GMR-PERFORMANCE is offline   Reply With Quote
Old 05-27-2014, 09:38 PM   #6
truckdude239
truckdude239's Avatar
I usec summit house brand teflon braid line and fittings no leaks at all first time doing braided line
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 05-28-2014, 09:47 AM   #7
blazer2007
Do I really need teflon for fuel ?
Old 05-28-2014, 12:54 PM   #8
Matt Cramer
I've found some of the cheaper brands are a bit harder to assemble - Summit's house brands are not all that easy, and the no-name stuff you sometimes find on eBay is the worst.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 05-28-2014, 02:18 PM   #9
tinydb84
tinydb84's Avatar
Depends on the fuel additives in your area. In California you do. The gas will eat through regular hose.
David
Instagram: myfabguy
Old 05-28-2014, 02:41 PM   #10
vin63
It's Better With Nitro
vin63's Avatar
Try to stick with one brand if possible and don't mix and match (I also had issues in the past with mixed-matched fittings). I mostly use Earls or XRP (mostly the latter on my projects) on customer jobs these days.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 05-28-2014, 07:11 PM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I've got Early, Summit, Jegs, Fragola and a few Aeroquip fittings, and they all play pretty nice together. I even have a few copper JIC fittings that do alright with them (just can't be tightened down to the same level.
Thats how the Aeroquip and large companies get you; Aeroquip makes lots of the suuuper high end unusual fittings, the kind you don't need....right up until you do. Last thing you want is to find out 1 fitting is going to change the whole system. This is why when you open the $10k box-o-fittings on a race trailer, it tends to be FULLY stocked by 1 company, usually a Russel, Earls, or Aeroquip.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
